l still have a fair amount of Floquil paints and as you would expect they need a considerable amount of shaking to make them useable. About 5 years ago I got the Robart #411 and have used it successfully to get settled paints mixed up. It died today
There are many negative online reviews documenting problems so I don’t have much confidence that I will get it working again. After using mine and seeing how it works I was thinking about just using some rubber bands to attach the paint bottles to an oscillating tool or a sabre saw.
Usually one or both hands, depending on how many bottles need to be shaken.
If the majority of the pigment has settled to the bottom, I use a piece of wood, like a tongue depresser, to stir things up, then re-cap the bottle and shake the daylights out of it.
I usually wipe-off the stir stick with a paint brush, so most of the paint is recovered - important if your paint is otherwise discontinued.
I often use self-mixed colours, so always label the bottle with both the name and/or its intended end use, and also the type of paint, and its required thinner.
I’ve never liked motorised paint mixers, even for house paints…too much clean-up required.
We will have to agree to disagree. I have had great results with that tool. You are probably not using it correctly.
I have managed to accumulate several bottles of the long discontinued Pollyscale paints. When I open a bottle, the paint is separated with the heavier component sitting at the bottom of the bottle and the lighter clearer component sitting at the top of the bottle. That bottom of the bottle component is often like toothpaste, if not thicker. Using the Micro-Mark tool, I get a perfect mix - - no shaking required, no mess.
Have you tried the Micro-Mark paint stirrer, Wayne? No mess, easy cleanup. You simply run water from the sink over the shaft. The Micro-Mark paint stirrer is a simple design, nothing like a house paint stirrer.
I have several of the Robart Paint Shaker models which I rarely use. I remember reading somewhere that mixing water-based acrylics using any method that entrains air is a bad thing? I do use the “drink mixer” type shown by Kevin on all my Scalecoat paints. Very effective.
Seems like the latest (and expensive" craze might be vortex test tube mixers?
In reality what I like to do is pull the paints I plan to use in the immediate future and put them in my pocket. After an hour of my warm body gyrating around I’ve given the paints a chance to get a little mixed up, along with the pocket owner. That works only if I manage to avoid napping, of course.
I also use the Testors ‘cocktail stirrer’. Some of my Poly Scale paints are probably more than 20 years old and they mix up just fine.
In order to keep my paints from hardening I always wipe the rim of the bottle and the inside of the cap clean when I use the paint. Not only does this provide a good seal when the cap goes on, but it also makes the cap easy to remove the next time I want to use the paint. I do it before mixing the paint so that any semi-solid paint film in the cap or around the rim does not get mixed into the good paint.
I’ve used the Micromart “stirrer” for many years. I’m on my second one now. It works beautifully for me, but there is a knack to using it.
The thing is, you don’t want to pull it out while still rotating as it will “spray the room”. So I learned early on to hold it so my forefinger is on the shaft, and I can vary the speed as needed.
Once I’m done with the mixing (or between colors), I move the stirrer to the trash can (with a plastic bag liner) and let it spin off the excess paint.
Yes, some semi dried paints have a hard bottom that needs to be broken up with a strong utinsil (screwdriver) and then the stirrer will finish the job.
From what I understand, this $10 tool is a major seller for Micromart.
The Badger paint mixer, shown in Kevin’s photo, and the Micro-Mark paint mixer, shown in the photo below, are essentially the same tool. When a fellow modeler first recommended the Micro-Mark paint mixer to me, I was skeptical. But when used correctly, as described in Mobilman’s post, the Micro-Mark paint mixer is extremely effective.
If the paint in the bottle has dried into a hard lump, off bets are off. But, if the paint has merely separated, leaving a soft lump at the bottom of the bottle, I have gone so far as to temporarily pour the clear liquid at the top of the bottle into another bottle and then added a small amount of Tamiya Acrylic Paint X20-A thinner into the bottle with the soft lump of paint. Then, I use the Micro-Mark paint mixer to liquify the soft lump of paint and return the clear liquid portion to the bottle, using the Micro-Mark paint mixer once again to finish the job.
I’m not sure that water will work with Floquil paint. IIRC, Floquil is solvent based so you will have to use a solvent to clean it up. I could be wrong.
All I do is wipe the stirrer blade with a dry paper towel as soon as the paint is mixed. There is no significant buildup.
With my ''cocktail mixer" i use a cardboard tube that fits my paint bottle neck. As I withdraw the mixer rod any splatter stays in the tube. By the way there is not much splatter in the tube.
I use worn down batteries so as to not stir up air bubbles in certain paints.
My Robart battery operated #410 that I have converted to wall wart power has given me good service. I had to buy new rubber straps about two years ago.
I have put muti bottles each in it’s own small plastic bag in my Lyman Turbo Tumbler with crushed walnut hulls (for brass shells). No bottles have been broken yet.
With non-water type paints I have a BB, the kind that ‘‘you will sh–t your eye out with’’ in the bottle. Just like a spray can when hand shaking. If you put the BB in water base paints the BB will rust.
Plastic wrap between the clean bottle top and the clean cap works good.
Oops, you did say Floquil. My bad. In that case, since Floquil is an enamel, you would need to clean the mixer tip in something like Tamiya Enamel Paint X20 Thinner, which is actually what Micro-Mark recommends. But, the principle is the same in terms of mixing new and old paint.
I was using the airbrush yesterday and have a small can of paint thinner left over from cleanup. I didn’t know what I wanted to do with it since it was from the final rinse and is very clean. Now I do.
BTW - I am talking about making unopened bottles that are 25 years old useable.
I purchased about a month ago, the Vortex shaker that you linked to. Small footprint on my bench, plugged in all the time, no off/on switch, it just starts when you press the paint container on it. Love it.
I had a bottle of stain, or something, that was about 35 years old unused. The content had hardened in the bottom with liquid still on top. As a test, I held it on the vortex shaker a few minutes and it completely mixed the product.
I agree with the comment that shaking acrylics can be an issue with bubbles. I don’t seem to have any problem with Vellejo, but I tried it with ModelFlex and it did create bubbles.
I’m sold on the Vortex for it’s convienience of use and it’s effectivness in producing results.
