paint stripping for restoration
Want to restore some old 600 Pullmans. I used to soak them overnite in some powder detergent and water, but can’t remember what to use. Does any one have a better idea, mthat leaves them ready to paint? Thanks, bill
Castrol Super Clean. A liter bottle with the top cut off works to hold the solution, and the solution can be reused many times. Soak for a day or two, rinse really well, and most paint comes off easily. A tooth brush to get into the creveses. Repeat as needed.
Jim
Have you ever thought of taking the shells to a automotive machine shop to have them hot tanked? You would be amazed at how shiny and factory fresh a junk yard engine block thats been painted and covered in decades of grease and rust looks afterwards. It isn’t expensive and you would probably get a break on price for the shells being “small parts”.
Since they are metal any blasting cabinet with the appropriate media and air pressure would work fine.
Are the shells plastic or metal? If plastic I’s stay away from the industrial dip tanks, (too hot) and the media blast may remove any details from the plastic. When I saw “600” I thought you were talking about the AF 650, 651, 655 etc.
The advantage of the Castrol Super Clean is it removes the paint (even chrome) with out any damage to the plastic.
Jim
Sand em doWn. Adds character.
