Painting Lead Figures
Hi! A recent visitor’s comments on our “O” gauge lead figures got us thinking.
First of all, we have no intention of “saving” them for their intrinsic value so the comment “Some look shabby and the faces are ug-y” got us to thinking. (Often not a good idea!) Why not repaint them?
Based on your experience, a good idea or forget it?
If good, where do we start and what paint do we use?
“Forget it” – It’s fogotten, their just fine as they are.
As always, many thanks for your input.
I’m sure Kevin can provide a better answer than I for this question. Perhaps he will chime in soon.
Simon
Easy way for quick improvement of O scale prepainted figures: Get some Minwax Walnut Polystain. Dip the figure in the stain and then shake as much off as possible. Let the stain dry for three days, and then spray with dullcoat. This will improve figures 500% and take very little effort.
DO NOT do this to HO scale figures!
If starting with UNPAINTED O scale figures, paint flat black as a primer. Use Vallejo paints and thin them with Vallejo’s thinner.
I paint figures as if they were getting dressed.
Eyes, skin, underclothes, clothes, accessories, shoes, and details.
Use at least three colors for every layer of clothing. A base, shadow, and highlight. The sun creates these in nature, but our layout lighting and small surface areas of miniatures will not. These must be painted on in thin layers.
Figure painting is a seperate hobby of mine. I have painted hundreds (maybe thousands) of wargaming figures. This carries over to model railroading, but it is up to you if it is worth the time and money to get all of the supplies and develop the required skills.
I can answer a lot more questions if you are interested.
-Photographs by Kevin Parson
I absolutely love figure painting, and I do not consider it a chore. Most people do.
-Kevin
So Kevin, you piqued my curosity Why should one NOT do this to pre-painted HO Scale figures - is the stain too thick? Is the results too dark or gloppy?
Also that jaunty figure in the brown coat and (I think grey scarf - seems like a Presier figure I have) seems rather unstable on that tank car running board. Clearly not an experience hobo…sorry, “train hopper”.
The Minwax Dip method leaves dark patches of stain in the recesses of the model. This exagerates the shadow effect, and removes the “flatness” of using only one color of paint on each feature.
Most HO scale figures have very low depth of details on the model. With low detail depth, the stain has nothing to flow into, and the shadows will all be in the wrong places.
This German Command Group is 1/100 scale, and was made by Battlefront Miniatures. All the features are overly sculpted and give much more depth to the details. This gives the stain a place to go.
-Photograph by Kevin Parson
I painted my entire German infantry collection with only six colors of paint for the entire army, and then dipped them for the shadow effect. It looks gloppy, but it does not look flat. When a couple hundred of these figures are on the table, it looks amazing.
This would not look good in HO scale on a layout. The figures would just look like they had been playing in the mud.
Army Painter makes a thinner dip that I have been told works better for figures like on a layout, but I have never tried it.
That is a Preiser figure. Preiser sells unpainted figures for a very reasonable price. They are a bit thin and spindly for my taste, and lack details, but they do paint up OK.
This guy is a cheap Bachmann figure. I like the way he painted up much better. His face actually had features to paint.
[img]https://i.imgu
Kevin and all: Many thanks for your insight. Appreciate your replies.
That I understand. I use a thinned wash of brown/black enemals over acrylic body paint to get the shading which looks decent enough to me. However, new and potentially easier techniques are always of interest to me.
Hmm, I have tried dip methods for other items that turned out (and other times was too gloppy). Maybe I’ll try dipping the figures into a thinned wash and see how that works.
I knew I recognized that figure, I have at least two copies of him as the big Presier unpainted sets would normally include dups of figure sprues meaning two copies of the same figure in
Here is an example on how the Minwax Dip Method works better on larger scale figures.
This fellow is 1/56 scale. The dip shadowed the figure much more effectively. I think I used 8 colors to base coat this model/
The way Minwax flows and sticks just does not scale down well to HO scale.
-Kevin
The minwax way is rather crude and not easily corectable. Much better to use Citadel or other shade colors and yes you can use this in HO which is my scale.
Yes, but the OP was asking about easy ways to correct O scale figures, so I tossed out the Minwax Dip as an easy way to add depth and shading without the need for much skill development.
It is “down and dirty”, but effective on the right figures.
I painted this Fire Elemental Demon with just two colors. I base painted it bright orange, dipped it in Minwax, then highlighted it with a drybrush of yellow.
Total brush time: About 5 minutes
Effective for tabletop: Yes
Golden Daemon competitor: No
Minwax dip on O scale figures will not make anything as good as this, but it will be a huge improvement over single color flatness.
I used Dot Filter on that green footlocker for the first time, and was very happy with the results. This is something I need to try out on freight cars soon.
-Kevin
