I have this old GP38-2 shell painted for burlington. Ugly beast. Ive been in the hobby for several years now and i want to expand my horizons. Im planning on painting this shell for my railroad the Southcross & Western. I made a few designs for different engines. if you have any suggestions for painting please post them.
One of my absolute favorite modern paint schemes is from a regional railroad known as the Arizona & California Railroad. (Green, White, & Yellow).
This scheme, IMHO, looks nice on EMD hood units. You could paint your Geep in this scheme as a “marketing trial” unit like some railroads have done before. (CSX did this when they went to the yellow, blue, and gray back in the late 80s—and of course it was a hit as most people did not like the “Stealth” scheme.)
If you’re not familiar with the scheme go to www.railpictures.net and then on the
“Enter Keywords” box type in Arizona & California. Some very impressive shots including an SD45.
What do you think?
well, sounds good, but i have already designed a paint scheme for my freelance railroad. southcross & western, if i could sort out how to post a pic ill show you.
here it is, looks much better if you click on it
For practice, get some cheap boxcars or cabeese & paint them in your scheme. Check out old issues of MR’s Paint Shop column for painting tips. You might find other multi-color roads interresting. In order to get the yellow correct, you may need a base of white primer first, Then mask & paint the yellow, with red on top & last.
thats what i was planning, yellow then red, its already primed white.
You didn’t mention how you were going to paint it. I assume you are going to airbrush it, although I have gotten good resusts from spray paints before. Even painting it with a brush will work if you are careful to try not leave any brush stroke marks. You will enjoy this new aspect of the hobby. It always gives me great satisfaction to sit back and look at a custom paint job and be able to say I did that myself.
My points have already been made by the others. I assume you will be using an airbrush. Is that right? If so, what kind? Different brushes handle different paints differently. [:D]
I must admit, you’re braver than I am. I have two engines that are waiting to be painted–but I keep chickening out. Let us know how things go–maybe it will help me work up some courage. [:I]
i dont have an airbrush, since my paint sceme is only 2 primary colors i thought i would just buy some cans of spray paint red and yellow. is that a bad idea?
here it is all primed and ready for paint.
Technically, that will work. But it’ll be hard to control the eveness of the paint. Its impossible to make a layer as thin as an airbrush with a spray can. You’ll be better off airbrushing. Mabey you can barrow one from a friend or somthing.
California Northern has the same paint scheme. Also, two of its GP15-1s have been transfered to San Joaquin Valley Railroad.
JPM,
Don’t chew me out too badly, but it “sounds like” you may be a little intimidated by the airbrush (as I was at first)[;)]. Believe me when I tell you that once you use an airbrush and practice on just one scrap car, you’ll likely never want to use a spray can again!!!
I used spray cans in the past. My best jobs were still a little rough or “orange peely”. After switching to an airbrush I was amazed at how easy it was to use. In my hobby room I have spray cans of dull coat, white paint, and clear that have been sitting on the shelf for years!..and very likely I won’t use them.
If money is an issue, you can get one of the cheap beginner brushes from Wal-Mart. If you want to go for the durable quality, save up your money and get something like a Badger 150 or a Paasche VL.
For no hassle paint that you won’t have to thin down, use Badger’s ModelFlex.
I’ve seen it happen with my wife’s cousin who wanted nothing to do with airbrushes. Once he painted his first locomotive…he went “Ga-Ga”[:p][:p] and started painting and weathering stuff left and right!
The paint scheme that you’ve selected for your locomotive is beautiful. Take the extra time and do it right. You can drop “hints” to your loved ones and let them know that for a Christmas present they can find a Badger or Passche airbrush at hobby shops or art supply stores!
Peace and Cheers!
airbrush price is not so much the problem, its the compressor. most people reccomend a tank for even flow right? cheapest one with a tank ive found was around $200. i would also need some kind of regulator right?
I don’t have any suggestions regarding painting… I think you are on your own on this one
Gord Bremner
I have the November, December and January issue in my home now purchased from
George’s trains in Toronto. Best Regards
Gord Bremner
I will get the February Issue at George’s Trains as soon it is available
Thank you
Gord Bremner
How much is a years suply of Model Railroader. I am in Canada… if the price is cheaper
than buying it a George’s trains please let me know???
Gord Bremner
bremnergroup@sympatico.ca
ok, went out and picked up an airbrush starter set for about $60. Practiced on some newspaper and now im mad at myself for ever using spray paint[xx(]. What i have runs off cans of compressed air. maybe one of these days ill upgrade to a compressor but this is fine for now. Anyway, is it just me or do these things really take 20 minutes to clean[X-)]
Hey JPM,[:D]
Glad you’re giving it a chance! The more you practice the better you’ll get! Regarding the compressor. I have a small electric compressor with NO TANK and it still manages to maintain a steady 25 p.s.i. I usually spray at 15 to 20 p.s.i. Yes, a tank is very good as it helps extend your compressor’s life and assures a good supply of air. A tank should definitly be added in the long run but it’s not required!
Since the compressor runs continuously, water will build up in the airline so a quality water trap must be be installed inline, otherwise you’ll see water droplets shooting out of your airbrush. I spliced my water trap on the airline and have not had a problem.
In the last 2 years I’ve switched to using Acrylic Paints like Badger ModelFlex or Polly Scale. Cleaning my airbru***akes me 1 to 2 minutes. I pour Isopropyl Alcohol in my jar, shake it up and then flush my airbrush out. I then gently remove the needle and give it a wipe with an alcohol soaked cloth. I also check the aircap for dried paint and wipe it. I’m done! That’s another great advantage of Acrylic (waterbased) paints. No long, cleaning up hassle! [:D][8D]
Now, if you do use a Solvent Based paint like Scale Coat II or Floquil then yes, cleaning will take just a little longer. The only solvent painting I do is metalizing with Alclad II chrome, which is great for making passen
