Jarrell, I think you should go ahead and take that one section all the way to basic completion. Lay the cloth, mold your rocks, mix your paints, and see how it all fits together, from 15 feet, from 4 feet, and from 6 inches.
If you don’t, you are proceeding under assumption, and if any of those assumptions turn out to not work the way you expect, you are committed.
We did a little section outside a U curve, then painted it, rock, drab foliage, peak foliage, dead foliage, dry dirt, moist dirt, and dusty roads. Then we grassed it and added trees too. Many grass solutions, and all the foam solutions are sort of fixed points in the color palatte. You only get a very few colors, compared to the variety you can mix up from Walmart dollar a bottle arcylics, and if the overall color balance doesn’t work the way you want, it’s easier to adjust one color in one small area than have to mask off and repaint the whole thing.
Speaking of masking, I wish we’d done more of that around the test scenery area. Chasing dried glaring white plaster out from between ties is less than fun. I was amazed at how far a brush will splatter, either with plaster or paint, and we did a lot more serious masking, with 1 and 2 inch masking tape and lots of newspaper for the main scenery effort, as a result of not using enough the first time around.
The plaster cloth went a lot faster after we started cutting 5 to 10 8 by 8 inch squares, 5 to 10 half squares, and 5 to 10 quarter squares, before laying any, it saved a lot of time over washing up, so as to avoid fouling the scissors, after laying each piece of cloth.
We mixed paint in mushroom jars, the 4" tall kind, enough for a 4x8 layout, but you need more. Mixing wet paint to match dry paint after you run out is not a fun or easy job. The mushroom jar lids are kind of a pain, I think regular threaded lids like on coffee jars would be easier to remove after breaks in the paint
