Painting plastic structures
What type of paint can I use to paint plastic buildings. What type do I use for weathering?
I use acrylics for everything. I am not very good at it, but it is not the paint’s fault. I have found the cheap acrylics work as well as the special model paints if the color is not an issue. For weathering; chauks, weathering powders and acrylic washes all have their place. Weathering is an art and I am not very good, but I have friends who are and it does not seem to matter what they use, it works. The best weatherer I know simply srapes some artist chauk with a knife and puts it on with a little brush. It really looks easy. I think practice is they key. A bigger issue for me has been finding good small brushes. Cheap does not seem to work at all.
Testor’s makes a variety of paints including a group of Railroad Acrylics under the brand name Floquil.
Here is a link to all of the Railroad Acrylic colors:
http://www.testors.com/category/137367?n=0
I use these acrylic paints exclusively on all of my structures.
They apply evenly and the brush cleanup is real easy, using just water.
Speaking of brushes, Testor’s also makes a variety of excellent brushes in three quality standards: good, better, and best.
http://www.testors.com/category/137231/Brushes
Eventually, some die hard solvent-based paint user is going to chime in and tell us we’re crazy, but for now, I’ll add another vote for acrylics. I use both PollyScale and ModelMaster Acryl colors, both made by Testors and widely available.
I use them both with an air brush and regular bristle brushes and they work fine for me. I weather things both with my airbrush and by dry-brushing.
I’ve never bothered to prime plastic models, although I do wash them first to get rid of mold release compound and dirt and oil. Paint adheres very well. Acrylics are usually dry to the touch within minutes and fully cured in about 24 hours. I use either Dullcote (after letting the acrylics dry for 48 hrs) or an acrylic sealant (which you can used pretty much right away) after weathering.
I guess we’re not really answering your question. You can use just about any kind of paint you want to, as long as it won’t attack plastic. Solvent based, acrylic, even household latex all work. Same goes for weathering… whatever works for you. Experiment and see.
You’ll find that in this hobby, there is rarely a “right”, “wrong”, “best”, “worst” etc. Everyone has his own preferences. The bottom line is, if it works for you, then it’s fine.
For everything except railroad cars I use spray paint available from Walmart or big box hardware stores. For railroad colors I use the brand that has the color I need. Testors, Floquil for example. I also have a number of military colors too.
Ace: Floquil oil base works fine on almost all plastics. Test out on the backside if in doubt. In 30 years of using Floquil I found only one piece that glazed!
For structures and figures, I use acrylic craft paints from Walmart or Michaels. They are inexpensive, easy to clean up, and come in a large variety of colors. The main thing to do for plastic models is to clean them off to remove any oils that may be on them, then let them dry thoroughly.
For weathering,I first use the same craft paint in an appropriate dirt color, diluted in rubbing alcohol. I use a 1/2" or 1" wide paintbrush to coat the wall and roof, and let it wash down and dry. I’ll use chalks to create rust effects. They too are pretty inexpensive, and a little will go a long way. I’m still using the same chalk set I bought ten years ago! An earthtone set will have pretty much every color you’d need.
You can practice on scrap pieces beforehand, if you wish. It’s easier than it seems to make a decent looking model.
John
Your correct about those acrylics, Rich, but the Testors site makes it appear, initially at least, that these are Floquil, a solvent-based paint. In actuality, they’re from Floquil’s line of acrylic paints, more commonly known as PollyScale.
You wouldn’t want to be labelled a “die-hard user of solvent-based paint”, would you? [swg][(-D]
I could possibly be that person, CTV, as I do have a preference for solvent-based paints. [:-^] However, I’m learning the idiosyncrasies of acrylics and have used them to good advantage, especially for larger structures.
One reason some of us are such diehards is that some familiar techniques that work so well with lacquer-based paints simply don’t work with acrylics. That’s not to say that you can’t achieve the same effects: however, it often requires the learning of new techniques. I have been painting with lacquer-based paints for over 50 years, but have found it useful to not dismiss new materials (and their associated methods) until I’ve tried them, so my paint cupboard is well-stocked with both types.
Nah. It’s not you, Doc.
As you expressed above, there are different techniques and methods which make the two processes and materials different, not necessarily better. If you say, “I don’t get the same results with acrylics as I can with ____” That’s fine. It’s a difference of opinion and you’re entitled to it.
I use red primer from Walmart. It closely approximates red brick. I keep gray primer on hand, too. I spray the inside walls with it. This prevents the dreaded “glowing building” when lit from the inside. Krylon has a line of “camouflage” colors that works great; and they’re all flat colors.
I use rattle can auto primers. The primers are all dead flat, stick well and cover (conceal what’s underneath) anything. Red auto primer makes a dynamite red brick color for brick buildings. There is also light gray and dark gray. The primers are all paint friendly, everything sticks well to a coat of primer.
Rattle cans avoid the problem of brush marks. If you can find the color you want in a rattle can (flat rather than gloss), go for it. Trouble is, most rattle cans, except the auto primers and some “camouflage” cans, contain gloss paint, brightly colored gloss paint at that. If the color you want only comes in gloss, you can give the model a final coat of DullCote, a clear flat spray from Testors. The DullCote will kill the gloss and tone down the color of the paint somewhat.
For weathering, powdered chalk is easy and looks well. And if you don’t like the effect, you can wash it off. One thing to be aware off. Handling will over time rub off the chalk. If you don’t handle the structure much, that’s not a problem. If you try to fix the chalk in place with DullCote, be prepared for a surprise. DullCote “marries” into the chalk and turns it invisible. I did this once, and after the DullCote dried, the model looked unweathered. Either skip the DullCote or apply the chalk VERY heavily.
Another weathering technique is the “wash”. You dilute some paint (black usually) down a lot, so you have colored water, rather than paint. This trick is probably best with acrylics 'cause the wash is a messy process, and cleanup with soap and water is easier than dunking things in lacquer thinner. The wash is applied with a paint brush and allowed to run down the side of the building like it was rain water. The color builds up in joints and cracks and mortar lines and looks like rain washed dirt. I’m going to do the mortar lin
Dstarr,
Not trying to pick on you, but are you sure you want to use a primer that “covers” anything. Don’t you lose a lot of the fine detail when you do that?
I often hear people complain about brush strokes. If your paint is the proper consistency (it should run freely off of a stirring stick dipped in the paint), it will self-level when applied to the model and not leave brush strokes.
You can also use an airbrush.
Also, when I weather with washes, I do a side at a time, and make sure that side is flat and level. If there is too much of the wash pooling at any one spot, I blot it slightly with a rag or shop towel.
If you’re painting brick structures, the final appearance will depend on the colour used for the brick, the colour used for the mortar, and the colours chosen for the weathering.
The Elfrida Stove Works (only those passing by in an airplane or dirigible can read the sign [:$] - I’ll get around to moving it eventually) was kitbashed from some broken wall castings (Magnusson, I think) picked-up for a couple of bucks from the “used” table at the LHS. It was airbrushed with Floquil Reefer Orange, then weathered with a wash (or two) of very well-diluted PollyScale paint, black or dark grey, with a couple of drops of liquid dish detergent added. The detergent makes the paint wash “wetter”, allowing it to flow more freely rather than bead on the surface.
Like CTV, I try to prevent the wash from pooling, especially around raised details on the walls. If the wash is very dilute, I let it dry flat, one wall at a time. For a darker wash, I often apply it to a single wall, then prop the building at an angle to control the downward flow. The corner of a paper towel is useful to siphon-away excess wash as it collects, and the angle can be altered and/or varied as the drying continues. Other times, the wash is applied to all walls simultaneously, with the structure sitting as it normally would. This requires constant attention to prevent pooling around details, and is often repeated several times. Like any weathering, you’ll have more control if you use multiple light washes as opposed to a single heavy one.
This structure, yet to find a tennant, was painted with the same Reefer Orange, but the first wash applied was a light grey, meant to represent, not too distinctly, mortar. Most is not especially visible, although it did alter the over-all colour of the bricks slightl
Aghhrrr, no doctorwayne, we don’t need no stinkin’ die-hard users of solvent-based paint. [tdn]
For sure, it is the Floquil line of acrylic paints, more commonly known as PollyScale.
Thank you for that clarification, good sir. [bow]
Yes, I want the paint to cover well. “Cover” when applied to paint, means the dried paint coat is sufficiently opaque to prevent seeing anything thru the paint. For instance, I use “For Sale” signs for my sheet styrene. I don’t want the brightly colored “For Sale” text showing thru the paint job. To cover well, the paint need not be thick, it just needs a pigment that is really opaque to light.
I don’t have an airbrush. I find that I get very good results with rattle-can paint, too. I have a large collection of different primers, which I also like for their ability to cover with a light spray, and their flatness. I don’t like heavy auto primers, though. Some of them go on pretty thick, which does tend to obscure the details.
Since I model an urban area, I have quite a few brick structures. So, I’ve accumulated a bunch of slight variations on “red brick” colors, so that my buildings don’t all look the same. I leave the original plastic colors on some, too, and other get browns and even tan. The different spray-paint companies all have slightly different primer colors, so buy a can of Krylon and one of Rustoleum to get a bit of variety.
I hand-paint the trim colors with acrylic craft paints, most of the time. I’ve I’ve got a large area of trim, sometimes I mask the building with blue painters’ tape and do a second spray with a different color.
Granted. But since I’ve never used a model primer that didn’t cover completely (unless I actually miss a spot), I didn’t think that’s what you meant. If I need something a little more opaque, I use a gray primer rather than a white. OTOH, since you’re using a “for sale” sign, you’re probably not worried about hiding the grainy brick / stone details on the underlying casting, are you?
I generally don’t need to prime styrene models to paint with acrylics, but if I do, I use the Testors spray primers, which cover completely without hiding details. I would have thought that an auto primer, which is designed to resist tougher environments, and not designed for fine details, would be too thick to work well on a model. But again, I’m thinking of things like commercial model kits and Evergreen / Plastruct styrene, not “reclaimed” materials.
Doctor Wayne,
You’ve nailed it-especially the unoccupied building and auction hall! Modeled brick can’t get much more realistic than those!
Dante
I found that applying your chalk/weathering powders while the Dullcote is still tacky works wonders. The chalk is pretty much glued to the surface and will withstand handling.
