If I lay track on cork roadbed, placed on top of plywood subroadbed, is it best to spray everything… the track, roadbed, and plywood subroadbed? Or, just paint the track?
That seems to make sense, but I wonder what others do. In the past, I have laid track on foam roadbed and never bothered to paint any of it, so I am curious about this phase of layout building.
If I were starting a new layout I would lay the cork. Then brush paint the plywood a dirt colour of your choice. Then brush paint the cork a colour close to your chosen ballast colour.
After laying track and wiring, then the rails can be rusted with a fine brush Selected ties could be brushed with various degrees of weathering.
This and ballasting can wait until you are sure the track plan does what you want.
Not all cork needs to be done before track laying starts.
I first brush paint the subroadbed a flat green along the right of way (or dirt or cinder color), leaving a bare path where the roadbed will be caulked to the plywood. I then lay the roadbed and paint mainly the beveled sides a flat gray latex. If it gets thick where the corner of the bevel meets the ply, thats okay because (latex) paint behaves similar to (latex) caulk.
I get some of the gray on the green, but that’s okay. In the real world, nothing is a perfect line where the ballast and weeds meet.
The flat paint soaks in and didn’t seem to bother the adhesion of the ballast glue mixture whenever you get to that point. Use flat paint in moderation over anything with a sheen. It soaks in better, sticks better, and other things stick to it better. You’re only looking to color the ply and the roadbed, not protect it from the elements.
Never having painted rail, I just assumed that the most common approach was to spray everything at once, rail, roadbed and subroadbed, and all one color. I like the idea of painting the subroadbed (the plywood surface) first, then laying the cork and painting it the color of the eventual ballast, then lay down rail and hand brush paint it.
Rattle can of rustoleum camoflauge brown. I stole the idea from Ken Patterson on youtube. Looks great when done, hides the feeder wires pretty well. YMMV
I painted the subroadbed after the roadbed was in place. I picked a “dirt color” from the local homedepot, and got the cheapest indoor flat latex paint (low voc). I also used the latex paint to adhere the base coat of ground foam on a section. This is actually seems to work pretty well, and saves a whole step of putting down a layer of white glue (the paint becomes the glue).
The poor guy at the paint counter was trying to sell me the expensive stuff, and couldnt fathom why I wanted the cheapest paint possible…until I explained why…
IMO
Hand painting the rail is a huge pain, and takes a really long time. (Ive done this). Painting the ballast has little to no benefit, since you are covering it with ballast.
Most recently when I handlaid some code 100 track, I rattlecanned my recycled flex track with the rustoleum paint, then stripped the liquid nails filled ties off and spiked the rail down.
OK, first I don’t use cork. Homasote or milled wood are my roadbed of choice. Homasote starts out grey, the color of my ballast.
Ever since starting to use Atlas code 83, and other track products with brown ties (most were black way back in the day), I don’t fully paint the track, just “weather” it.
I do hand paint the sides of the rail…
The neat and well cared for mainlines of the east in my era then just need some dulling down and blending together to look realistic.
Once again, I can’t imagine using a spray can…I own several air brushes…
Oh I can imagine it. I used Rustoeum camo brown on my last layout based in Rob Spanglers most excellent layout and recommendations. The results speak for themselves when you see his layout photos and it doesnt get any better than that!
The best MRR painting “scenery” video I have seen said to start with an absence of colour. This was the best advice I’ve learned to date. It suggested you start with a flat black or dark brown, I chose a dark dirt brown.
I put the cork down and painted all the foam brown. I didn’t paint the cork gray to match the ballast at first but changed and started to paint the cork gray later on. This covers any spots the ballast may escape from over time, it will likely go unnoticed. The same with the brown, if someone brushes against the dirt, you are unlikely to notice that as well if you get a little bare spot. Getting a little brown on the cork or a little gray on the brown won’t matter as it gets covered in the end with foliage or ballast.
Paint the track before you ballast. I use the rusty rails painter or airbrush as my mood dictates. I really like to use the rusty rail painter to add highlight colours to the ties. A little gray or black muck here or there looks great. The rusty rail painter is great for adding oil stains after the ballast is added as well. When I use the airbrush on the track I use a camo brown usually and then roll the rusty rails painter to add a slate colour here and there and then lightly roll on some rust on the spikes here and there.
I have been really happy with the results I had.
A word of caution, A couple of years after I had painted all my foam brown, I put down my yard tracks and turnouts directly on the foam and held them in place with “T-Pins”. Over time the latex paint reacted with the ties and the track is firmly in place being held by the paint. I did the same with some “temporary” sidings, and when I went to lift them up, the paint was stuck to the bottom of the ties and not the foam.
As far as the plywood, I paint it green or brown before laying the roadbed, but it can be done anytime before laying the ground foam or dirt.
As far as rails, I’ve used rattle cans and brush paint in the past, but have settled on brush paint. Rattle cans cause the basement to stink and you’ll have a tougher time removing the paint from the tops of the rails since rattle can paint sticks very well.
I use a big artists chisel brush to paint the rails and the ties at the same time, since the sides of the rails and the tops of the ties on the prototype tend to be the same crud color. I nestle the brush long ways into the crease thats formed where the angle of the ties and rails meet. You can move along quite quickly. I’m not that precise with the application, since cheap dark brown latex paint wipes off the tops of the rail pretty well. The the chisel brush never strays far when held into the crease anyway, so the paint pretty much goes where I want it.
I just mix the colors as I go using a palette and blend them further with the wet paint I just laid down. I mix brown and black. No need to have everything exactly “rail brown” all over the layout.
If you want that new rusty look, a fine artists brush can apply orange in places over what you’ve just painted, and stay on the sides of the rails.
Dried latex paint scrapes off of the tops of the rails quite easily with the edge of a credit card. Something metal w
