OK…for all you new to the hobby of model RRing…here are some tips on painting that the “old Yard-dog” has passed on to several forum readers already, so here they are for anyone guessing about colors and matching the prototypical RR or military colors.
Acyrlic paints- mix and clean up with water, blue tint windshield wiper fluid and isopropyl alcohol, and they do not smell like enamel paint.
These paints can be found at any arts and craft section in Walmart, Hobby-Lobby type store. They also come in gloss which is an enamel based paint but with the features of acrylic. It too matches colors found on RRs.
Matching colors…this is no problem, with color charts found on the various websites, Walthers catalog and other sources one can match these with any military color and RR color. One could go so far as to label the paints with the listings from paint samples.
Application and durability… airbrush mixes go on a little thinned at higher psi, about 40-60 psi and hand brushed on with a little water to thin the paint. You will find this type of paint will stick to almost any surface, it will weather nicely, and you can mix it with powered chaulk to flatten ( remove all reflectiveness ) and mix the black and grays with powdered pencil lead to "metalize " plastic or wood to make it look like metal, i.e. my plastic bridge sections now look rusted and weathered after this treatment.
After each coat which should be several thinned applications, dry the paint with a hairdryer set on LOW heat, this acts like a poor man’s paint bake shop and will set the paint. After several hours the paint will be rock hard and will not come off very easily. -
Experimenting and kid’s projects.
Don’t be afraid to play around with colors and surfaces to paint, if you make a mistake and the paint is still wet
