the led’s burned out in the switch target. anybody know if it is a standard LED, I dont see a dropping resistor in the circuit. thank you,
From page 11 of the owner’s manual for FastTrack Switches
OK, I will drop by tonys and see if he has the LED, The lED’s came on then went out, That is why I was wondering if there is a dropping/limiting resistor missing in the circuit. LED’s need a resistor in 99% of applications. I have the same LED problem with my 6-24101 signal. the red & green leds dont work, yellow ok but not r&g, could be a wiring problem their also.
thank you,
dave j
Note, it says EXPECTED, kinda like “your mileage will vary”,
Just unsolder the old one and install a new one, when its out ckeck the voltage should be about 1.7 -2.2 volts.
Here’s a link on led’s check it out.
http://www.kpsec.freeuk.com/components/led.htm
Joe j
The only way to be sure is to draw the circuit out. The LED is directional so don’t solder it in backwards. The Kelly school is a fine site. I have used it too!
