Hi I’m looking to get some replacement plastic dowels for the pony truck on my Bachmann 4-6-0 mine are worn at the ends and some are splitting, I live in the UK but Bachmann over here can not get spares so if any one in USA knows of a supplier please let me know[:)]
Are you referring to the spacers?
About 1/2" or 5/8" long, 1/4" diameter, hole in the centre for axles?
Locally for you, no idea.
Shipping to the UK will be more than they are worth.
Do you have sources locally for solid plastic rod?Carefully drill out the centre for a press fit of the axles, cut to length (1.575" back to back).
Barry’s Big Trains used to make these on a lathe…not sure if I have any around any longer.
Parts from Bachmann would most likely include the entire truck.
Are you capable of making your own, or do we need to go on a search?
TOC
Hi, Its finding a company that has the stuff I want the UK is very short on this sort of spares
How big are the spacers?
Computer mother boards have small plastic and metal spacers.
Hi the part I need is the part that goes between the wheels on the pony truck IE the four wheels on a 4-6-0 engine
If I recall correctly the part you are looking for is a plastic spacer that keeps the two half axles (and wheels) from touching and creating an electrical short.
On the 4-6-0s I’ve seen the part does not bear any weight. If this is the case, have you considered using vinyl tubing with an internal diameter the same size as the half axle shaft?
If it would work you would have an inexpensive replacement part.
G’day from Australia, I have had the same problem and found two solutions. A. “hard” plastic irrigation or compressed air tubing of the appropriate size worked well. B. a length of nylon “bearing” rod machined on a lathe to the required size was the prefered method. No further problems with both methods for me. Regards Phil. joyphil@midcoast.com.au
Did you look thru their (u.s.) online catalog ?http://estore.bachmanntrains.com/index.php?main_page=index&cPath=66_69_148&zenid=qa0iq1r3f45pkak89irasufjm4
nite
