PATH trains to Newark (EWR) airport ??
Port authority is going to do another study of running PATH trains to the airport.
http://www.progressiverailroading.com/passenger_rail/news/New-Yorkarea-port-authority-to-study-direct-rail-extension-to-Newark-airport--32570
first study I heard of was in 1966 in conjunction with the ALDENE plan. Now 46 years later still another study. (number unknown )
  1. Original plan was stopped by a colition of the then powerful taxicab and private bus companys.
  2. would think that AMTRAK would not want to give up any ROW as the PATH train tracks and storage yard now split the NEC tracks south of Newark Penn station and north of Hunter CP.
  3. building PATH extension on an elevated track also seems to not be in AMTRAK’S favor as AMTRAK’S long range plans may be for an elevated track for the future HSR vision plan with a second level station at Newark Penn ?
well, that’s nice … though taking the PATH to Newark Penn Station, and catching a train from there to EWR isn’t terribly bad (though, honestly, I’d have rather gone to Penn Station and taken AMTRAK home… )
Yeah, this is another round of the same ole same ole. However, I like the idea in some respects because at present NJT trains stopping at EWR have to add a couple of minutes to their schedule which can back up traffic if there are delays, etc. So that might be good. Amtrak is OK with the EWR connection which can be a boon to airl and Amtrak if properly marketed and executed…
As for space. There is actually more space today for PATH than there was years ago since the PRR freight stuff is gone for the most part and a lot of the storage and lay up track space is unused. Slipping a pair of PATH tracks would be much less of a problem. I wonder, too, if Newark Penn even enters the picture, in fact. There is room to make a path off the PATH main somewhere east old Hudson Tower, perhaps even as far east as Journal Square, and cut across to the airport without even touching Newark city limits. But extending from the station by flyover west of the CNJ bridge, and going west (south) along the eastbound side of the Corridor is possible. The question is should PATH terminate with the monorail or go right to the EWR terminal building and the monorail dissappear? Money has been announced for the mono’s improvements.
Running trains through to Newark Airport will not require any more track space at Newark Penn Station, and the platforms are large enough and long enough to handle additional traffic easily.
First-hand knowledge from my 1995 PA-Acoustics analysis.
Less sure about this one, but I think the flyovers are in place now, because the two pocket tracks south-west of the station are on the east side of the right-of-way (or that is what my memory says), and the line to the Airport could just be an extension of those two tracks unless some trains were to continue to terminate at Newark Penn. I think the business might be sufficient to extend all trains to the Airport. Also there is the possibility of restoring service to Edison and other local stations that were dropped by NJT for insufficient ridership. Mybe not, though since passibly a non-stop Newark Penn - Newark Airport ride would be preferred.
Yes, Dave…there is plenty of room at Newark Penn at this moment…the concern is west (south) toward the airport. There actually is a lot of room to build a pair of tracks to the airpor both on the ground and on trestles as needed. The question I have is whether PATH would go to the airport or to the monorail/EWR station on NJT/Amtrak. I would think it should go to the airport eliminating a change of modes otherwise it would not be as attractive.
Do you have any idea of what prompted the Port Authority to reopen this question? As I recall the idea of extending the PATH train was considered at the time the monorail was planned. The PA rejected the idea and built the monorail instead. The issues raised now seem to be exactly the same. There is no suggestion that the monorail is overcrowded or inadequate. The costs of operating the monorail are still with us unless the bonds have been paid off and extending current PATH trains would both be expensive and compete with the monorail.
When the monorail was built it seemed to me that extending the PATH train would have been wiser for all of the reasons that are cited now but the transportation planners, who presumably are experts, thought a monorail was better. So why the current change of position?
To make Newark Airport, which has capacity for added flights, more competitive with other Eastcoast airports.
I just don’t see how a PATH-Newark Liberty Airport connection would make the airport more competitive, Dave. Right now Amtrak stops at the airport so there is a connection from every Amtrak station from Boston to Richmond, Va. From mid town Manhattan New Jersey Transit serves the airport. It would be more convenient for airport bound people from Hoboken, Jersey City and lower Manhattan who live near a PATH station but they only need to make one change at Newark Penn Station to get to the airport. At this point where is the competitive advantage of a direct PATH-EWR connection?
The more services available, the more connections available, the more usefull and accessable the airport is for anyone. There is a lot of perception there, but perceived services and values mean more to Americans than actual benefits. But I also think the monorail connection is a problem for many…it is an extra cost. PATH would probably, or should, have a direct connection to the airport terminal and avoid the monorail. This would help NJT especially, by elminitaing the stop if not entirely but for many trains, helping them move trains faster. Amtrak probably has to most to gain with keeping the EWR stop and the monorail connection. But if PATH can provide a one seat ride (always a mantra in NJ and NYC area), even at an extra fare from Newark, it sure would relieve a lot of road (auto and bus) traffic in and around the terminal area. One of the major markeing adjustments a lot of us have to make is that most travel, air travel in particular, is not for the wealthy or for business people on expense accounts, that it is as common as a commuter bus or train for many, and therefore a rapid transit connection, like PATH, instead of luxury buses or taxis, can be a well used service in addtion to being useful in alleviating traffic and congestin, environmental impacts, etc… And if it can be done without having to make too many transfers, all the better.
I think you are right about the cost of the monorail, especially for frequent travelers. It costs $5.50 per person with children under 11 free. I think that is pretty steep. Up until recently I was commuting between Newark Penn Station and Trenton. Coming home from Trenton in the evening we would always pick up several passengers at the Airport terminal. Only rarely did they get off at Newark; it was easy to tell because they all had baggage. I suspect almost all of them went on to New York Penn Station.
Frugal travelers can take the Number 62 bus at Newark Penn Station. The one way adult fare is only $1.50. You are allowed two bags on the bus and there is some restriction on size. The bus stops at Terminals A, B and C.
And PATH could add on up to $2 after Newark Penn if need be, as long as it went directly to the airport terminals with one, two or three stops there. People will pay for convenience. Plus if there are no stations after Newark Penn, it should also be quicker than the bus and much more convenient and cheaper than NJT/monorail.
One of the things I can’t remember off hand was whether or not the earlier proposals for PATH had this as part of the proposed Plainfield extension…
I’m sure you are right, Henry, about a PATH fare with a $2 surcharge to get to Newark Airport. Right now New Jersey Transit charges $12.50 from New York Penn and $8.25 from Newark to the Airport.
I didn’t mean to suggest the 62 bus is as fast as Air Train. It isn’t. But if you have the extra time and not too much luggage it is no more difficult to schlepp from the PATH train to the bus station than to schlepp from the PATH train to the ticket window and back to the track for the Air Train.
When the monorail was being planned there was some talk of continuing the PATH train to Plainfield but nothing ever came of it.
I don’t doubt that even train and transfer at EWR is faster than the bus. But the real service clincher for many is as few transfers as possible. Even, or especially, the 62 bus from Newark Penn Sta reprsents a transfer from NTJ, Amtrak, PATH or other bus but eliminates the extra fare of the monorail. Thus I feel a PATH train direct to two or three of the terminal buildings on a loop through presents the service and the price could be regular PATH fares or with a premium from Newark…depends on how many, if any, stops there are between Newark Penn and the airport. I wouldn’t expect Amtrak riders or marketing to use PATH, but I would expect more from the NJT operations. In fact it would give NJT a chance to either bail out of it entirely or the fine tune their marketing and choice of trains that did make the EWR stop.
I agree, Henry, that a PATH train to EWR with a one seat connection and a lower fare would be convenient and popular.
What I don’t understand is why the Port Authority would want to duplicate the current service. The spent a lot of money building the monorail and the EWR railroad station so why would they now build a new railroad connection that can only compete with what they already have? I don’t even see why now they want to spend money to study a new PATH connection to EWR so there is something going on I don’t understand.
It is what public agencies do.
Aside from that snarky remark, I think they are looking and a new era and new needs, They are looking for what they have to deal with in the next 25, 50, etc. years. If they don’t keep investigating and thinking about the future they could get caught flatfooted and die or screw things up royally. Who knows what they will find or have to come up with to deal with it all. The current situtation maybe could be better or better off replaced…only a study will tell.
PATH service direct to the airport, without the use of the monrail shuttle, would mean one could walk through securitiy, pick up bags, etc., and board a train to a station directly adjacent to a Mnhattan hotel, any of the five Manhattan stations.
This should make Newark preferred over Kennedy until Kennedy gets its own subway link. But isn’t Kennedy already at capacity. I know LaGuardia is.
It is disappointing to this poster that the article was not read.
The article says that PATH is studying the expansion to the AIR TRAIN station only not to the terminals! I was operating out of EWR airport a lot while the AIR TRAIN was being built and also when the AIR TRAIN expansion to the NEC station was also being built.
A bit of history is needed here.
  1. Newark airport was the first airport for the New York area then followed by LaGuardia, then Idlewild ( JFK ).
  2. Much of the present airport land was not part of the original airport.
  3. When building the present terminals ( 3rd itteration ) dirt piles up to 30 - 40 ft were placed over the future foot print of the buildings to compact the soils.
  4. Several unknown crossing utilities were broken at that time and bypassed but some remain to this day. there were many pipe lines crossing the land as this was once a large refining area.
  5. when the present terminals were built many utilities were mis located on drawings and when the AIR TRAIN was built a common occurrence was loss of a utility during foundation and other excavation work One time the whole terminal “C” lost electrical power after a casing borer cut the power feed.
  6. I have no idea if all utilities have been properly located but suspect they have not been to this day.
  7. To bujild PATH to the airport terminals would require engineering the work in stages with foundations located and then relocated when necessary. Only then could above ground work be designed and constructed. That would require too many years IMHO.
Speaking for myself, Streak, I did read the article but I didn’t read it as carefully as I should have. Also when the headline at the top said the Port Authority will study service to “Newark Airport” I assumed the article referred to a place where you get on a plane rather than a place where you change trains. Silly me.
According to the article the Port Authority hopes to attract commuters who will park in its airport lot. Right now up and down Route 1 there are a number of parking lots at NJT’s stations. By driving several miles furthers those NJT riders could park at the airport and switch to a PATH train. This would move a large number of commuters from NJT to the PATH train. Current PATH fare with a multi ride ticket is $3 per day, $66 for a 21 day month. From Metro Park to NY Penn Station NJT charges $284 per month. Of course the Port Authority would need to reconsider its monorail fare ($5.50 one way) as well as airport parking fees (long term parking is $18 for the first day). However, they have excess capacity in their parking lot and on the Monorail.
Meanwhile what happens to NJT’s loss of revenue from commuters and other riders? This sounds like a return to the competition of the 1870’s and 80’s and is in the spirit of Jay Gould.
Except that NJT says it is running at capacity through the existing tunnels to Penn Station. Shifting some of that passenger load to PATH, and structuring PATH to absorb it without problems, could mean more people using public transit. I have long advocated doubling the Jersey City - Newark service by running uptown trains to Newark instead of terminating all of them at Journal Square. The problem of the capacity of the pocket to reverse trains would be handled by having hostlers assigned to Newark to releive the road engineers, having one at each end, and not requiring the trains to spend time in the pocket tracks for the road engineer to walk from one end to the other. A two-minute headway on JC-Newark section would then be possible.
Dave underscores what too many people overlook: the world is always changing, the NY Metropolitan area is always growing. Predictions are for increased population; increased truck, bus, and auto traffic; increased rail traffic. Planners are not thinking the status quo but increased population and increased transportation needs in the near and distant future. The Great Depression of the 30’s was good for the US in that FDR saw fit to put people to work building highways and other infrastructure which allowed us to fight WWII and to achieve Post War economic prosperity because the transportation infrastructure was 80% in place with only a few turnpikes and other four lanes to be built into the 50’s. Then Eisenhower saw fit to expand the highway system to what we know today to augment what had been done previously. We cannot face 21st Century poplulation growth and passenger and freight transportation needs using 19th and 20th Century left overs…we have to build and alter more to increas the capabities of our infrasatructure. We are relying on business to take care of freight and calling on government to take care of people. But soon the two are going to have to come together to put into place a program that divides up the land and resources and work to a system that accomodates the new Century needs of society. PATH trains from inner city to Newark Airport is only a small first step. We’re going to see a rail service from Newburg and Stewart Air Field in NY into the area for instance, and perhaps an actual loop like service through the airports; a more regional rail system rather than just Amtrak and the commuter agencies; maybe more airports further out of the area linked by rail services; improvements in port facilities in both size and interfacility connections. It’s no longer the burgeoinging age of the Industrial Revolution; patterns of people movements and commodity movements are different and wil be
