PCM PRR I1sa shots up!
Precision Craft Models have got the test shots of their I1sa model in. Apparently they will be shown at TrainFest, but for those of us who can’t go, there are already photos on the PCM website.
Here is the web site for the I1sa. I included the description which is boiler plate. They have the Aurthentic sounds with articulated chuffs again for a 2 cylinder engine. I guess they want you to purchase one sound and one non sound and run them double headed. HA!
The picture looks like a pilot model in progress.
http://precisioncraftmodels.com/PCM-089-PRR-I1sa,-2-10-0,-Modern-Headlight-Position-4268,-LokSound-DC-DCC,-HO-i29398-c3144.html
  • Beautifully Detailed, Accurately Modeled Locomotive and Tender Body
  • Authentic Design, Paint and Color Schemes
  • Authentic Sounds with Articulated Chuff (Sound Equipped Units Only) and Prototypical Operation
  • Many Separately Applied Details Including Brass Bell / Rails
  • Detailed Backhead
  • Operating Cab-roof Vents
  • Constant Intensity Directional Lighting
  • Lighted Number Boards
  • Factory Installed painted Fireman and Engineer Figures
  • Seuthe Smoke Unit Ready
  • Traction Tire Equipped for Maximum Traction
  • Locomotive Composition: ABS with Die Cast Chassis
  • Tender Composition: ABS with Die Cast Chassis
  • Locomotive Length: 6.8"
  • Tender Length: 4.2"
  • Total Coupler-to-Coupler Length: 11.6"
  • Motor type: 5-Pole Can with Skewed Armature & Dual Fly Wheels
  • Couplers: (2) Operating Kadee Compatible
  • Compatible Tracks: Code 70, 83, 100 Rail
  • Recommended Minimum Radius: 18"
"DCC & Sound
