Peanut Ridge Underway (photos)
In photo #1 you can see Peanut Ridge shaping up. I named it b/c BB the beagle and I sit up on the ridge eating peanuts together. The ridge upon which the tracks run, is constructed with rocks, some weighing about 100 pounds. Fortunately, I have a pickup truck and include heavy deadlifting (heavy to me, that is) in my weightlifting routine. You can see the tracks heading towards the stream, which they will follow shortly. It ain’t all going that quickly b/c I’m handlaying the tracks (upon which remotely controlled O gauge toy trains run).
In photo 2 and 4 you can see some additional lakes I put in since last time. These are shallow and formed with concrete and cinder blocks, morticed together.
I planted additional trees, a native specie called virginiana juniper, one of which is shown here in photo 3. Really adds to the variety of the other trees. And scales out very well.
In photo 5 & 6 you can see the trackwork, freshly ballasted (ballast needs some brushing to remove excess).
Photos 7 & 8 show Peanut Ridge, which will be extended quite a bit up to a 6 foot long girder bridge. The sides of the ridge will be filled about half-way up with dirt and then scale ground cover will be planted. The reason for the ridge is so that the trackplan I’m using stays fairly level, as my backyard slopes.
[img]http://im1.shutterfly.com/procserv/47b6da31b3127cce8810b496000a00000015109QZOX
