I am thinking of adding some of Peco’s Setrack switches to my layout and was wondering if they will fit well with Atlas flextrack which I have on my layout…Anyone with this experience…
Melchoir,
You have a duplicate thread:
http://www.trains.com/community/forum/topic.asp?TOPIC_ID=67748
You should delete one of them. Just go to the upper right hand corner of your original post and press DELETE. You’ll need your password to complete the deletion. Thanks.
Thanks Tom…Enjoy your day…Michael
I use Atlas flextrack with Peco Setrack switches. The only problem I run into is that Setrack (and most european track in general) is made for big wide flanges, and American semi-scale flanges tend to fall into the frogs. One solution is to put thin strips of acetate or other plastic into the inside of switch frogs to give a little less clearance. Or if you use wheelsets with deeper European flanges you’ve got no problem.
