Does anyone know the curvature equilivent of thie double slip switch is? (#4, #5, #6)
Thank you,
Richard
Thank you,
Richard
Hi there,
All of Peco’s turnouts are meant to be an angle of 7 degrees so a “large radius” and a “small radius” or medium radius together will correctly space a double track crossover.
The different radii used to be considered to be 2ft 3ft and 5 ft but they were not strictly speaking circles i.e. you would not get a perfect circle laying the curved parts end for end. I would think that the double slip would be translated to the large (quasi 5ft) radius given the spacing needed for the points of the slips.
Cheers from Australia
Trevor
Perhaps this page has the information you are looking for.
https://peco-uk.com/products/crossing-double-slip4?_pos=2&_sid=057f2c9f6&_ss=r&variant=7264231227426
Good luck!
Thank you.
I believe all of the streamline code 100 turnouts have a diversion angle of 12 degrees. Thus matching up with the 12 & 24 degree crossings.
use the 12 (long)to cross an adjacent parallel track. 24 (short) to build a double crossover
