Pennsy radio antennas
Does anyone know when the Pennsylvania RR first start installing the large roof mounted antennas and when did they remove them?
They called it the Trainphone. The system started in 1945 and was phased out around 1967. When they actually removed the antennas might be another story.
As an add on question… How much of the Pennsylvania was equipped to use the TrainPhone?
I understand it required lineside equipment also to make it work. If this is true, it would have been a huge task to install it all across the line.
Was it used mainly in rural areas or urban areas?
-Kevin
From a 1953 booklet “Pictorial Review of Progress on the Pennsylvania”
PRR_1953progress by Edmund, on Flickr
Regards, Ed
A few additional notes gathered from some of my documents:
PRR and Union Switch & Signal began development just prior to WWII. The prototype installation was in September 1941 on the Belvedere Branch. By June of 1942 a locomotive and cabin car had been equipped and additional wayside equipment installed. The developmental installation was complete by 1944 on the line between Trenton and Phillipsburg, New Jersey.
At that time ten locomotives, ten cabin cars and one wayside station, Frenchtown, NJ, were equipped for a full trial. For this installation the carrier was on a 5.7 kilocycle AM frequency.
The signal was radiated at so low power that an FCC licence was not required.
By 1947 the installation grew from the initial Bel-Del line to two main line divisions between Harrisburg and Pittsburgh initially on passenger engines and shortly after in freight locomotives and cabin cars. The single carrier frequency was changed from 5.7 kHz AM to two FM frequencies 88 and 144 kHz. Selectors on the equipment were marked L or H for each frequency.
Although some descriptions say the signal was carried through the rails it was actually lineside wires that picked up the signal. If the wires were a distance of more than 150 feet from the track an additional wire was strung closer to the track and insulated from ground.
The transmitter loops were the prominant feature of locomotives and cabin cars. A wire was placed inside this pipe. On cabin cars the recieving loop was placed inside a disc-like case. Sometimes these were used on locomotives if space was a problem.
PRR expanded Trainphone to most of the system by 1940 excluding the electrified zones.
PRR attempted to develop a “Carryphone” which was a thirty-pound box with a handset and loop antenna on the bottom of the box. It never got past the develo
What does “radio equipped” mean?
I have a Santa Fe caboose that is a traditional red except that the coupla is painted white. From some info I found, that white coupla was supposed to mean that the caboose was radio equiped and was capable of traveling in PRR territory.
Does that souund right? If so, I would like to know more about how that caboose was used in PRR territory.
If I’m not mistaken, the run-through agreements came after the Penn-Central merger. Sure they were run on former PRR territory but Trainphone was long gone by then.
Some of the railroad radios had limited frequency selectors, say six or eight channels or so and they were tuned with plug-in crystals. Perhaps the specific Santa Fe cabooses had radios that included the frequencies needed for communication on Penn-central’s road frequencies.
http://members.localnet.com/~docsteve/railroad/scanfreq.htm
Today’s radios can digitally tune any of the needed frequencies.
Ed
This thread is just giving me more questions…
I painted the cupolas on two STRATTON & GILLETTE cabooses yellow, mainly just because I thought it looked good and mixed up the fleet a bit.
Does the yellow (or white) cupola actually indicate the presence of special equipment?
-Kevin
The yellow and gray cupolas were to designate pool service cabooses, yellow was for east and west and gray was for north and south.
Rick Jesionowski
