Pennsylvania 0-6-0 No. 634 to operate at Williams Grove Steam Show
The short stretch of track that the PRR 0-6-0 runs on runs parallel to NS’s ex-RDG Lurgan Branch for a short distance. The PRR also used to make an appearance at this location. Until 1979 the ex D&M, CV, PRR, PC, CR Dillsburg Branch operated next to Williams Grove Park where the Steam Show is held every year. The Dillsburg Branch operated from Mechanicsburg to Dillsburg, approximately 7.2 miles and was even electrified at one time. This was prior to the very well-known PRR electrification between NY - Washington -Harrisburg, etc. In the early 1900’s, two trolley wires were strung between the two towns to power a PRR coach converted to motor car and a trailer coach if needed for passenger train service between Dillsburg and Mechanicsburg where one could change trains for Harrisburg. Two trolley wires were used and set off to each side so that steam powered freights could still use the line without fouling the trolley wires with smoke (at least in theory). The electrified passenger service ended around 1929 but freight service continued until 1979. The line was state-subsidized under Conrail for three years but never included in their Final System Plan. Years ago this Labor Day weekend celebration was known as the “Granger’s Picnic” and many attendees rode the Dillsburg Branch to get there from either end. I believe there i still a bridge located at D&M Junction just south of Williams Grove where the Dillsburg Branch ducked under the Reading (NS) Lurgan Branch.
