I’m trying to find some good information on the “pennsylvania modified” type of truck.
They were present on some of the belgian railway car and i need to create one in 3D
The are the type with 3 heavy spring between the two axles
weight was +/- 4.8 tons and a distance of 2.4m between the two axles
Doesn;t open on the actual site, either, only the picture of the cars shows.
However, if you use Google image search for the file name, you can see the picture.
Looks closest to a 2D-P6 to 2D-P8, if they had a coil spring for the bolster instead of an elliptical. Maybe it’s one of those that is missing a picture from the other web page linked above.
I looked through a couple PRR truck sites and did not see the match. However, welcome to the forum. First post in 9 years? In this country we would say "Don’t be such a stranger’
