Got a question for the CW-80 experts out there… I’ve got an 8x8 layout with essentially two loops–my track plan is a ripoff of Spankybird’s 5x8 circus layout. I’m powering it with a postwar 1033 and 1034, one on each loop. For the types of trains I run, they do OK.
I’m about to wire it for accessories, and I’ll power my switches and all the lights off a third transformer. I could put the 1034 on that duty, or my CW-80. I’d rather use the 1034 on accessories, since the wattage is lower. If I remember right, it delivers about 63W of usable power (it’s rated for 75), while the CW-80 will deliver very nearly 80W.
I’m doing bus wiring with a common ground. I know this is a no-no for DCS, but I’m running conventional and plan to keep it that way.
I suspect the CW-80 might not like being yoked with a 1033, since the CW-80 doesn’t create a true sine wave. True? Also, can the 1033, 1034, and CW-80 be on the same common? The voltage range of the 1034 is a bit lower. I have run the 1033 and 1034 phased together with the U posts connected in the past (they aren’t now) but I don’t know if that was something I shouldn’t be doing or not.
Thanks for your advice!
