Philosophy Friday -- A Single Industrial Theme
“A Single Industrial Theme”
US Steel Railway Yard
US Steel Railway Yard, c 1920’s
Last week we discussed the pros and cons of paired industries, where the product of one industry on the layout is supplied to another. This week let’s talk about layouts built around a single-industry. There are a number of industries that we could be talking about here-- an obvious one that springs quickly to mind might be a steel mill, which can be so large they could easily dwarf and moderate-sized layout all by themselves. With their own dedicated tracks, yards, switchers, rolling stock, and even customized types of rolling stock, not to mention the variety of resources they require, steel mills all by themselves can make a very interesting thing to model and never leave the boundaries of the plant.
But it isn’t limited to steel mills. Another example might be a logging company who uses the railroad to haul timber from the hills to the mill, and to haul in people, equipment and supplies to support the lumber camps. And to haul lumber and wood chips to factories that manufacture furniture, paper, leather, or other products from the wood or one of its byproducts. Or perhaps a layout could be built around some sort of refining operation. Cars bringing in oil or other distillates to be processed and producing petroleum, propane, or some other chemical product.
I’m sure there are lots of industries that could potentially be large enough to be the focal point of a layout all by themselves.
No, definitely not! My choice is to see train movement not parallel tracks of standing stock in yards…
But I’m posting because my prefered area is Chicago so the big “single industry” for a long time period was meat. Much more interesting than steel…
[:P]
No, I would find it very boring. I am very interested in both freight and passenger operations of all types.
My industrial areas are much like a stand alone “Industrial Switching Layout”, but if that was the whole layout, I would not be in the hobby.
Sheldon
My layout is about cement. I have two cement plants, and just one warehouse. The train I use to follow when I was younger was all cement, and I always wanted a cement layout. I have a main plant (Medusa, well renamed Zeus). The other smaller plant is “Blue Star”.
The hoppers kinda go back and forth to each other, while the boxcars can carry some to the warehouse. Of course I still have a yard/town/etc…but its mainly cement.
Blue Star (the smaller plant):
The bigger plant. It was called…Zeus “strong like the gods”:
A small shipping company “Lakeville”
Years ago when I first got back into model trains and started planning my layout I really thought about building it around the auto industry, particularly the GM assembly plant in Oshawa, Ontario. I drive past it on my way to work every day so I see how much train movement there is first hand. Both CN and CP switch the area so I started to plan and design something. Both GO Transit and VIA Rail run trains just seconds from it as well. Just the over all size I needed soon turned me off of it. It did offer a ton of switching but not much scenery other then huge buildings. I tried to scale it back but the shear beauty of the idea was it’s huge size.
This is where my story gets funny. I’m sitting in a boat in Northern Ontario doing some fishing close to what I thought was an old run down train bridge when the most beautiful thing I had ever seen cruzed by me. A nice and shiny Ontario Northland SD75I, a SD40 in the older chevron paint scheme and a GP9 in the same paint scheme as the SD75I went by me pulling a bunch of freight cars AND some passenger cars. I thought to myself how freaking cool is that. Just looking around where I was, in the middle of no where and this train motors past me. That’s when I decided I was going to model the Ontario Northland. I haven’t looked back, as much as I wanted to build something on one single industry I found I prefer to just railfan most of the time. With the auto industry layout I planned I couldn’t do that.
There was an interesting side bar to an MR article into the 1960s about a mining layout design for a bedroom. The essence of the sidebar was that while building a single industry layout can be very interesting and a lot of fun, operating a single industry layout tends to be boring for many. The inherent boredom is evident by the way single industry advocates and article authors are very quick to point out that the operations are more diverse that what we would ordinarily expect - methinks too quick.
A real railroad wants as much “dull” repetition as they can get. Repetition of trains, loads, empty movements, etc., means costs are easily determined and relatively constant. Variation to the standard operations represent a lot of uncertainty, which is difficult to price. That’s why variable operations are often (perhaps usually) performed as an overlay on top of a standard, non-variable process rather than mixing the two together.
If we are accurately modeling the prototype in operations as well as physical plant, repetitive operation should play a major role. Serving a single indust
If “No”, have you considered building a layout around a central industry? If so, what was your concept and how would it be developed?
There are 2 different industry roads I would consider modeling-a logging railroad based on the switching of the saw,plaining,plywood and veneer mills as well as the loading area and interchange…Power would be a 2 truck Shay and maybe a Climax.
The second would be a narrow gauge coal hauling railroad that would haul coal from the mine to the transloading track yard.The transload dock and standard gauge railroad would not be modeled.The scale would be On30 and power would be a Bachmann 2-8-0 or 2-6-0.
A “single industry” layout? My layout currently under construction is almost a single industry layout, if the wide umbrella of a SEAPORT can be considered an industry. The largest freight traffic to the layout consists of export goods being sent TO the port, and imported goods rail-shipped OUT from the port. The different facilities of the port may seem like separate “industries” though.
Solid trainloads of grain in boxcars going to the export elevator–
(unfinished scene)
About hyalf as much traffic in cotton to compresses for export.
(background scene drawn after cotton sheds at Galveston.)
The prototype ran trainloads of sulphur for export, but since the distinctive cars require a scratchbuild, I will probably have to settle for cuts of 6 to 8 cars…
Inbound, a banana ship came once a week with more than a trainload of bananas to ship north in reefers…
There was also a “bulk material unloading dock” which brought in occasional shiploads of ore several times a year…an excuse to concentrate empties for the shipment.
“My” port also imported shipments of raw coffee, and sugar.
Yes and no! The emphasis on my Santa Fe, as I have stated many times now, was Oklahoma in 1989, in particular, Enid Oklahoma and the massive terminal grain elevators and flour mills. The Santa Fe served Enid via a branch from Guthrie OK northeast through Enid to Kiowa Ks on the transcon main. The SLSF and CRIP also served Enid and between them, and the railroads that took them over and the Santa Fe, from June through the end of July was a madhouse.
I have chosen to model the grain elevators to represent the many elevator companies of that era. I also have Oklahoma City modeled with its elevators and all the towns on the Enid branch with their elevators, plus grain trains coming from Kiowa on the Santa Fe to Enid. The grain arrived for many elevators to be stored, while old grain was moved out for export in the gulf coast region. The Enid branch had only one town with a siding long enough to pass trains, so the grain trains at Guthrie and the trains at Enid were “fleeted” over the 45 miles of track, which makes a great scene on the layout. Enid also saw grain coming in from big elevators in Kansas, plus Oklahoma and west Texas.
Enid did have a refinery, the Champlin (home owned originally) which is now gone, but I kept it alive so I had traffic tank cars, etc. There also a large chemical plant on the ATSF and BN east of Enid which I also model. Those three industries, grain, petroleum, chemical are the major players on my Santa Fe. Grain leads, with a total of 30 grain elevators on the three decks of the railroad.
This means large fleets of grain cars, and Intermountain, Atlas, ExactRail and Tangent cars make up the buld of the300 plus grain cars.
Bob
Do people count as an “industry?” If so, then yes. Much of my layout is devoted to serving the people of Moose Bay. There are trolleys, subways and bigger inter-city passenger trains. I’ve got 4 stations underground, 2 stops for the trolleys above, and I’m building the station for the “big trains” right now. There are buses and cabs on the roads, too, for those who just can’t get enough of that public transit.
While the layout I’m building is principally focused on the South Pennsylvania Railroad, a bridge route between Harrisburg and Pittsburgh PA, it will also incorporate a second railroad, the Montour RR, that actually operated in a belt around Pittsburgh. The Montour is interesting because it served the coal industry almost exclusively. At its height it had about 48 miles of track and 27 coal mines.
Montour SW9 83,76, & 74 Jan 1981
When the Montour dieselized, it standardized on small EMD switchers.
Moon Run Yard Coal Tipple
Moon Run Coal Tipple
Montour Mine #10
Montour Mine #10
The Montour made its living almost exclusively servicing the mines along its route.
My layout is built around a single industry, the movement of citrus specifically lemons and oranges from packer to consumer, obviously packing houses dominate this theme, but packers also produced byproduct that was shipped for use as fuel for power plants and livestock feed. I do things big, my packers are all based on a specific prototype, Cornona Packing has a capacity for 28 cars and has an in house lumber mill and cull processor.
Sunkist Ojai was a much smaller operator with a 12 car capacity on three spurs, but had extensive shook manfacturing facalities to support affliates. Red Vine Rasin Association (despit the name it never processed a solitary grape or rasin) was served by two operators and had spurs along 3 sides of the building each serving a specific product line, obviously the prototype found it useful as a interchange point as well and when times were lean the adjacent dairy operations provided some much needed revenue, they also shipped cans of milk and butter by LCL and sold excess power to the communtity from the in house steam plant!
If I were truly ambitious, the Tropacana Juice plant would be next on my to do list, it would require around 30 square feet to convey the magnitude of the operations. Who knows, i’ve done the research, but what the heck did they use avacados for? I suspect as a fuel source as an major avacado processor was located across from the plant and spoilage was typcially seperated for anminal feed with the pits used as fuel, whatever its eventual prurpose, demand was so great a conveyor belt feed avacados to the site and was a known consumer of avacado pits from as far away Texas. How many times have you seen gondolas filled with rotting advacados modeled?
To keep this fluid requires a fleet of over 200 reefers per operating session with a secondary need for boxcars intended
A single industry layout doesn’t appeal to me. Part of the appeal of model railroading is the moving of trains from one place to another. I also like the wider variety of a common carrier line. Switching cars around a steel mill (or other plant) as the whole layout just doesn’t appeal to me.
If I were doing a small layout, I would do a single station layout before a single industry one.
I’ve never seen a plan for one, but a Railroad Car Builder would probably be the best. You could have a whole variety of cars and they could be brand new with fresh paint jobs for a variety of roads.
Enjoy
Paul
Things in my version of Central Japan in September, 1964 tend to come in threes. Thus I have three private railways that each serve a single industry. One will be fully modeled as part of first-phase construction. The other two will start as (almost) static displays, to be extended out to second-level operations when, as and if…
  • Fully modeled, the Tomikawa Tani Tetsudo. Serves a big colliery and a ‘three couples and a dog’ operation, carrying coal to the interchange with the Japan National Railways at Tomikawa. Other freight traffic is almost all mine-related, shipments of goods to the mines and to the bigger mine’s company store. Lots of passenger traffic (including school trains.) Even in 1964, access to this area was by rail or goat trail.
  • Slightly operational, the Kashimoto Forest Railway (762mm gauge.) If you figured logger, you got it in one. Interchanges with the JNR at Tomikawa.
  • Static display (to start with,) the Harukawa Electric Railway (762mm gauge.) In 1964, the hydroelectric construction along the Harukawa Gorge is entering its final phase, but the rails haven’t fully transitioned to their later status as a tourist route. 762mm gauge Schnabel car, anyone? JNR Interchange point is Haruyama.
As an aside, there won’t be a millimeter of dual-gauge track at either Tomikawa or Haruyama.
This photograph elegantly shows the need for tracks on either side of a tipple. Makes butting up a tipple and tracks against a hillside look silly.
For small/medium layouts, I favor a major, high-volume industry with a mixture of lesser industries.
Mark
Aaahhh, what a loss. Dual guage is neat/cool/interesting/intriguing/etc. And costs so little for a master turnout builder like you, Chuck.
Mark
Yup, I do steel!
But that’s not everything, maybe just 70% of the local traffic. Being a SW Michigan native, I saw a lot of steel mills and was always fascinated by their architecture, machinery and broad assortment of rail car types, so I always dreamed of modeling one. My HO mill occupies its own peninsula between two larger ones in the center of the trainroom.
However, I also have at least 7 other “industries” (incl. team track and an interchange) that are completely unrelated to the steel mill. Plus, the main line is a bridge route that supports a fair amount of pass-thru traffic [to spice things up a bit for the operators of the Local]. I’ve also positioned view blocks to keep some areas of the layout visually isolated from the mill.
I’m quite satisfied with the overall theme. Plenty of variety in traffic, and my regular operators all seem to have fun with it!
I agree that probably people need to consider what they’re building, but there are just as many examples of the mine against the hillside as well:
John
John, you missed my drift. I’s talkin’ 'bout the backside. Tracks shouldn’t dead-end at the tipple. They should go beyond so a cut of cars can be accommodated, as illustrated.
Mark
Oh yeah, absolutely. Complete agreement.
John
