“Double-Heading and MU Lashups”
N&W Y6 Double-Headed - East of Blue Ridge, VA (From N&W Historical Society)
On the real railroads, double-heading-- or more probably nowadays-- multiple unit (MU) lash-ups are common occurrences. On model railroads double-heading often presents additional operational considerations that can make running multiple locos the occasional headache. For instance, if the speeds of the two (let’s say) locomotives are not closely matched, then one will pull or push the other which can cause problems with train handling, malfunctioning or breaking couplers, or even in extreme cases could cause one locomotive’s motor to wear out prematurely. When operating multiple units together there are really two components to consider, the physical match of operational characteristics between the units, and the subtlety of control available to fine-tune or compensate for discrepancies.
With plain DC control, since all locomotives operate from a common control and power source, the secondary control adjustments that exist with DCC and other onboard control systems, are not available. Thus the principle method of assuring good operation between multiple units lies in tuning and adjusting the physical mechanisms themselves. That, and making sure that locos have good motors, gears, etc., and are properly lubricated. One common technique is to make sure that double-headed / MU’d locos have matched gear-sets / gear ratios so that the motors and wheels turn at pretty much the same rate at the outset.
DCC, and presumably older methods of on-board train control, introduces the second
