Hi,
I wanted to post some photos of my HO layout so far. You all have been very helpful and I am very thankful for all of your advice.
Thanks,
Kevin
Hi,
Thanks,
Kevin
Looks very nice and interesting. Is that a spot for a turntable in outline? [:D]
Looks very good. The few sidings look well placed and it should be fun and challenging to operate.
Have fun!
It looks like it will be fun to operate…but a little off topic question for you. Is the pin up art by Vargas? It reminds me of his Esquire work but I don’t recognize any of the particular pictures. Which is odd because I have a lot of his work (They don’t seem to be colorful enough to b Elvgreen or Petty)
Hi,
That round thing is leftover piano wire that I used on my throws. The Vargas are from the War Years 1941-1945.
Kevin
what I would do (i did it) is put a pile of ballast at the end of the spur it looks a lot cooler and is effective just put glue on the stopper and pour the ballast on top of it it looks really neat! good luck!
Looks like the throws are from Caboose Ind. I did my first Caboose throw a few weeks ago and I was able to connect it directly to the TO.
Why did you need to use piano wire ?
How are they connected ?
And, Good job [;)]
The piano wire went from the throw, under the track, to the center hole in the switch.
it looks realy good!, (alot better than mine) Good Luck!!
