i have been trying to find pics of a caterpillar 160H motor grader on a 60 ft flat car as i have a norscot model. i have looked at the fallen flags site and some others without any luck.
thanks for any and all information
tom
tom
Hello Tom,
This is the best I can do for now. It’s a photo of two Volvo graders on a 60’ flat,although not caterpillar,but I think it will work for you.
http://www.rrpicturearchives.net/showPicture.aspx?id=107198
Patrick
Beaufort,SC
Dragon River Steel Corp {DRSC}
Making HO scale steel by the ton
Tom,
This is the sole article citation I found at the Index of Magazines searching for a Caterpillar load:
Monon Flat Car and “Cat” Loading: Next step for realism Mainline Modeler, March 1988, page 40 ( BULLDOZER, CATERPILLAR, FLATCAR, LOAD, MON, “SWITZER, MONT”, FREIGHTCAR, MM )
At least it might give you some idea how they secured their loads in '88. Also,
you might want to look at the NMRA “Open Loads” article series in the NMRA Bulletin/Scale Rails magazine. They also have published a booklet of some of those articles. Hope this helps.
Bob
NMRA Life 0543
pat and bob thanks for the help and information.
pat the pic really didnt show the tie down detail but it should help out some.
bob im gonna have to find that issue of mainline modeller
once again thanks for the help and information
tom
Tom,
Here’s the link for back issues of Mainline Modeler:
http://www.hundman.com/cgi-bin/estore.cgi?ct=1
Or, you can order a photocopy of the article from the NMRA’s Kalmbach Memorial Library:
http://www.nmra/org/library/
Their charge is reasonable, even if you’re not a member.
Bob
NMRA Life 0543
