I’ve been posting ballast pictures this morning so I thought I’d post these:
Plaster tunnel lining made from a mold. Only used near portals:
Flipped up (Al foil is painted liner for other tracks):
Here’s a bridge inside my mountain to cross double tracks. It’s a steel plate with a red rubber pad under the cork. There’s an angle bracket extending to a side support. A coat hange from the top also helps stop vibration. That’s my control panel opened up in the corner of my cave. I can disconnect 2 bales and move it.
I had some trouble making the transition from a 4% grade to level. Note the 12V lightbulb in the blue part (screw-in fixture used to light buildings).
[img]http://im1.shutterfly.com/procserv/47b5d609b3127cce9383953015d600000016108BatXDZq5bo[img]
