Piggyback Loading in the 70's
Yea, your right, if using it right out of the box, it would need some “bashing” to get it to the right width.
That, or start from scratch.
Mike.
Cherryville NC.
Yes, Cherryville, my father was the Baltimore terminal manager for Carolina from 1967 until about 1979.
Sheldon
Live their allmost of my life drivers for Carolina did not like piggyback they said it took jobs,and i did know that Mr Beam did own stock in the Seaboard Coast Line.
That portable ramp I vaguely remembered has been found. It was made by Penn Line and advertised on p.15 of the May, 1958 MR as their kit number A1-K, with “die cast sidemembers and safety pattern metal deck.” Price: 75 cents, in 1958.
I’d just widen those from Walthers.
I spent several years around Springhill, and did some consulting in Minden.
Neither of the railroads going through there was a serious ‘through’ line by the early Nineties, and I think it likely that any organized piggyback traffic would depend on a regulated environment … or a supportive local Chamber of Commerce wanting to expand local intermodal. The completion of I-20 to the south would put a very effective kibosh on any particular piggyback ‘advantage’ in Minden.
I can’t imagine the level of traffic that would justify a Letroporter or sidelift gear for that town, or even assignment of some kind of yard tractor for loading and unloading. So I think portable ramps and circus-type loading would be the only real practical solution; my guess is that some careful instructions about ‘which way the trailers faced’ might be involved as part of the routing instructions. It is at least possible that, in your era, there would be at least the equivalent of a wye between lines on the Shreveport (west) side, so you could switch ends with only a few moves; this might be an interesting thing to model if you have the space.
What year did trailers move from being transported on single flatcars or two flatcars in tandem to those articulated spine cars?
Also Athearn just rereleased some 50’ Flatcars with 25 trailers, but they appear to be lettered for 70’s era railroading.
Were any 25’ trailers around in the 70’s? Or was it mostly 40’ and 45’ trailers?
Single trailers have always moved on single flatcars even up into the 1990s as trailer lengths grew, often before flatcar length could catch up. In the late 1970s, up into the 1980s, railroads converted surplus, or outmoded equipment into cars capable of transporting newer, longer, trailers. Railroads such as Southern, CNW, MKT, cut 50 foot boxcars down into trailer movers. Santa Fe used re-purposed bulkhead flatcars from wallboard service. Prior to that, some railroads cut down old gondolas and applied tie-downs.
Athearn’s 25 foot tandem axle trailers and 48 foot “piggyback” cars seem to be from that great 1950s “NKP”–No Known Prototype-railroad. The cars have no hitches or tie downs, and no bridge plates in an era when it was all circus style loading. It seems to be a matter of a manufacturer adding “play value” to their product offering instead of following a given prototype.
Shorter trailers similar to Athearn’s were extant right up to today, but most trailers less than 32 feet in length were single axle. The 40 foot trailer became legal in 1957, making the 75 foot flatcar obsolescent. In 1981 the 45 footer became the new standard and a trailer building rush was on. Owners with large numbers of relatively new 40 footers began programs to “stretch” them an additional five feet. By the time everybody had their 45 footers in service, trailer length jumped to 48 feet in 1985. In 1991, 53 feet became the new standard although some juridictions permit 57 footers.
“Piggyback & Container Traffic” by Jeff Wilson, (Kalmbach Books, ISBN: 978-1-62700-383-4) will answer your intermodal questions. The spine car concept began in the late 1950s with New York Central’s Flexi-Van container cars. In the late 1970s, Santa Fe began experiment
And here is all you have to do make the Athearn cars closer to the real 54’ cars carrying two vans:
Remove the excess axles on the trailers, move the landing gear back, modify the rub rails, add bridge plates and bridge plate retaining chain stakes, and create some fifth wheel jacks. I skip the binder chains, but add spare tires to many trailers, which were common in the 50’s.
Sheldon
That looks more like 50’s piggy back - wasn’t this topic about 70’s?
Topic drift.
Well the topic was also about unloading, but NHTX brought up the Atheran cars, so I chimed in. And as he explained, once trailer lengths pasted 40’, railroads returned to “one trailer per flat car” methods like my last photo, so the topic did not really drift that much…yet.
Yes, two 25’ vans on a 50’ (+/-) flat car was a 50’s thing. Single longer vans on flat cars is a 50’s thru today thing.
Actually, in the early 50’s, several roads had good sized fleets of 40’ flats to carry a single 32’ thru 40’ vans. Some of these started life as flat cars, many were converted from old box car underfames, B&O, NEW HAVEN, etc.
Early piggyback is full of home shop conversions, the prototypes are endless, and there are virtually no commercial models, and very little detailed documentation, often just wide shot photos and roster notes.
The B&O museum has a 40’ piggyback flat built from a box car frame.
But as asked and answered weeks ago, portable ramps were common until circus loading ended.
Sheldon
When it was still the Central.
Years ago when it was still the Central we were schmoozing around the Buffalo area and passed a small yard where they were backing truck trailers up a simple sloped ramp onto TOFC Flats.
The ramp was a framework of used heavy timbers possibly from a bridge deck which was filled with cinders, ballast and so on. Across the track end was a heavy timber with a notch cut in so the Drawbar of a TOFC Flat could be pushed right up against the ramp, steel plates laid, and trailers backed across, the guide rails on the car sides holding the trailer in place until spotted where it could be hitched to the car deck.
Low Cost, Low Tech.
The brake had not been set on the Flat and the Trucker, as he backed the Trailer along the flat car deck, set his trailer brake. The flat car moved in response, and the truck tractor fell into the now-gap between the ramp and the
Personally, right from the initial statement, I saw this as being Trailer Train 89’ flats or the equivalent. It would be the 1970s, perhaps even as alternatives started to make those cars ‘surplus to requirements’ – someone more knowledgeable than I am about specific car history, like Carl, might know exactly what classes would likely show up in service with the kind of demand of a Minden ramp.
But it sure wouldn’t be '50s-style trailers on wood-deck flats in that era.
As noted in an earlier post, the single trailer on a single flatcar was by no means dead in the 1970s, or even the 1980s. Although many of the original 40 foot piggyback flats were gone by the 70s, Trailer Train rostered hundreds of 53 foot cars that were former PRR F-30 class flats that were converted in the 1950s. Some of these cars remained in service into the 1990s, carrying 45 and, 53 foot trailers.
Trailer Train also bought Pennsy’s 75 foot F-39 pioneering pig flats, on TTX’s start-up in 1956. They had wood flooring with exposed steel center sills on their decks. The former PRR F-39s were rapidly outmoded when trailer length jumped to 40 feet in 1957. New Haven, Southern Pacific, Kansas City Southern and Erie embraced an 80 foot car “system” known as the Clejan flat car. The Clejan had a raised center sill that formed a railway for trailers equipped with small flanged wheels. This system was history by 1963. The only trailers that could be carried were those with the small flanged wheels-- basically a closed loop system at a time piggyback was exploding.
The Clejan did contribute to piggybacking by being the inspiration for General American’s G-85 and, later, G-89. General American kept the raised center sill, instead of rub rails along the sides of the car. The G-85 was introduced in 1959 and, ACF, Pullman-Standard, and Bethlehem all introduced their 85 foot flatcars to carry the ubiquitous pair of 40 foot trailers.
The 89 foot flatcar owes its existence to the auto racks of the day. It was discovered that adding 4’4" to the basic 85 foot auto rack would increase the carrying capacity by three automobiles. Trailer Train wisely made the 89’4" flatcar standard for both services. The 89 footers began arriving in 1964 and served into the 1990s. The
NDG wrote: “Years ago when it was still the Central we were schmoozing around the Buffalo area and passed a small yard where they were backing truck trailers up a simple sloped ramp onto TOFC Flats.”
Conrail (and probably the New Haven and PC before it) had a similar setup at Cedar Hill in New Haven.
When I was a new hire fireman on switch engines in the yard, one of the jobs of the afternoon shift was to pull out the loaded trailvan flats, and make up train TV-7 to Springfield (it would get combined with a B&A westbound to Selkirk).
Later on I got to be fireman on TV-7 for a few trips. Went up to Springfield, and turned for mixed freight back to Cedar Hill in the wee hours of the morning.
That raises the question, though, where they would be going PASSING THROUGH. Minden at that point was served by an east-west secondary line (which I think changed owners between the first time I saw it, in the mid-80s, and the early '90s when I started working in the area, and was largely shut down thereafter) and the ex-L&A that went to Hope, AR before it was cut back, first to the Taylor area and then Springhill itself. The major service on the latter was traffic to the IP kraft mill, which is scarcely going to be facilitated by trailer intermodal, and when that mill closed I don’t think its ‘replacement’ services, whatever they were, particularly needed TOFC either. All the TOFC in the world would go down the SSW branch parallel to Rt. 3, just a few miles to the west, straight from connections with the ‘main’ SSW parallel to Rt. 82 to Bossier/Shreveport itself.
I happened to be frequently driving from Springhill to Shreveport (via local roads over to 3, as Interstate 20 was impassably deranged with slab lift at the time) just at the time the SP got its new Dash-9s in the 4400 series. It was possible to pace a pair of these all the way down without impeding traffic, at considerable speed, and I really can’t imagine any priority traffic going any other way through that area.
I know the pig tracks were originally built for loading trailers of ammunition from the Army Ammunition Plant in Minden but I am not sure what year that was and how long it was used for that purpose.
The Minden of 1976, the year of Flying Crow’s interest was on the Hope Subdivision of the L&A Ry which extended from Hope, AR, to Deramus Yard, according to KCS System Timetable No.1, Effective 12:01 a.m. Saturday, Jan. 1,1977, for the government of employes only. The Minden Subdivision of the same L&A Ry, extended from Minden LA to Pineville Jct (Alexandria LA). Although the same employes timetable lists Minden as still having a “TOFC ramp”, by 1976 the operation of a TOFC ramp 30 miles east of a major terminal is questionable. In 1976, the passage of piggyback traffic through Minden is not impossible, since it did provide an alternate route between Deramus (Shreveport) and New Orleans via Alexandria. An interesting note on the Minden Sub is, the Rock Island had trackage rights on the 56 or so miles from Winnfield, into Alexandria.
Also, pardon the thread drift, but the last engines to occupy the 4400 series on the SP were SD-9s. The only other recent SP locomotives with any relation to “4400” were the 4400 hp GE Dash 9-44CWs acquired in 1994 which were numbered 8100-8200 (101 units).
I had a post disappear that regarded the ammunition plant in Doyline. The ramp in Minden is almost certainly a Vietnam War thing, perhaps to minimize perceived drayage risk for certain ‘secure’ or high-value explosive products or incoming supplies or key munitions components. Cutoff of ‘active’ traffic might be related to changes in the plant’s staffing and operation in 1975, around the time the ARVN finally folded up; the OP’s modeling in 1976 would likely see the ramps in an early stage of post-‘abandonment’ decay.
Funny thing about those dash9s is that I distinctly remember big reflective numbers in the 4400s on their shiny new paint… before I learned exactly what they were or their rated horsepower. (I also remembered 4935 as being restored in Tuscan, so I have been known to be very wrong before…)
The transport of explosives such as produced by an ammunition plant is to be minimized as much as possible, given the passions raised by the Vietnam War. If the products of this plant were to be piggybacked instead of shipped by boxcar, logic would say put the ramp for loading the flatcars on the grounds of the ammunition plant which would certainly be rail served. This would remove a considerable number of vehicles carrying a very controversial and hazardous cargo from public exposure on Minden’s thoroughfares. Most ammo facilities shipped their stuff out the gate and gone, with as little extra shuffling as possible, which makes the old boxcar, the ideal vehicle for door-to-door delivery. Most, if not all such shipments began and ended behind the gates of secure, government controlled or, contracted facilities. After 20+ years in the U.S. Air Force, I’ve seen a lot of ammo handling and storage facilities and, the tracks went right to them, instead of stopping in town, and trucks hauling it into the facility over public roads. The sight of 18 wheelers loaded with stuff that goes boom, lined up at a public piggyback ramp in a KCS yard, waiting to be backed aboard some flatcars, in a Louisiana town, 30 miles from Shreveport, is difficult to reconcile. Non-volatile components might arrive by piggyback but, outbound ordinance or ammunition, highly unlikely.
Your recollection of the Dash 9s triggered the memory of my first acquaintance with SP’s new, wide nosed units. One westbound freight was stopped on the main, with a green signal staring at him, while the other westbound in the siding was headed by SP 8139 and 8140. The crew saw my interest in the new power and invited me up into the cab and gave me the tour. I asked what was going on, since the other man had a green eye but, was just sitting there. The answer I got was "Haven’t you heard? We
