I need to span 3 tracks with piping. I was thinking of using a bridge like this to do it.
While I could build it completely from scratch I was hoping to find some box girders already completed to use to make it easier. Is there a product like that out there?
I am also open to other solutions if anyone has ideas.
I had always used orange label on ABS with good results. About a year age I was working on something in ABS and had a senior moment and just used MEK. I realized my mistake after completing a few joints. They turned out fine also.
That would be a great idea if I didn’t have that signal bridge about 18" from where the the pipe bridge will be. Thank you for mentioning it though because I want another and couldn’t remember the brand.
If the Bachmann signal bridge would be considered usable, then one might also consider the NJ International two track signal bridge. The support structure at each end consists of two parallel vertical beams instead if the tapered beams on the Bachmann model.
IF you’re modeling HO you might look at some of the N scale bridges available. I forget if this one is Faller or Kibri but I’m planning to use it in this area as a pipe span across the tracks here.
