It depend’s on how their going to be unloaded at the destination.
Forklift ? Load them on a flatcar.
Overhead crane ? Load them in a Gondola. Plus , in a gon they dont need to be tied down, just strapped to each other to keep the pipe’s from shifting in transit.
Another consideration would be length of the pipe. 80 foot lenths of pipe do not fit in gondolas unless you use drop end gondolas and put the load accross both cars . I am not sure if the railroads would favor that over putting them on an 89 foot flat car.
Mike,Thanks for posting the video…When I was at the hobby shop this morning I picked up some Evergreen .047" round tubing to emulate that load.
I picked up several strips of scale 2x2s and Evergreen Plastic tubes and beams. I bought the last two Atlas/Trainman Bulkhead flat cars he had in stock and a IHB gon. The gon was a last minute impulse buy. Glad I bought though.
When I worked in Texas all the drill pipe (4-6" dia) came in gons and all the big pipeline pipe (18"-48" dia) came on flats. Virtually all the gons came from railroads in the NE.
According to an FRA inspector who used to give clinics to our local NMRA division, there are FRA restrictions in coupling a pipe load on a flat next to a tank car, because a shifting load could puncture the tank, unless it is a bulkhead flat. Ditto for pipes or rods or other loads of that kind on a gondola where the load is higher than the end of the gon. Sometimes you see gons with improvised bulkhead ends that go higher so that the load is protected against shifting in that way. You also see some gons with permanent ends that are higher than the sides of the car presumably for that some purpose and reason.
In spite of that FRA restriction I have taken photos of unprotected open loads next to tank cars that have hazmat placards. I also have taken photos of loads that have shifted in just the way the FRA is concerned about.
