PITTED RUST "TESTORS CLEAR PARTS & WINDOW MAKERS CEMENT"?
Ckeck out the link below. I am not sure if this is the stuff. If you read the description it says
For professional results each time, use non-crazing Clear Parts Cement & Window Maker.
So is this the glue they are describing? I have been dying to try this stuff to get DRIPPING & PITTED rust results. I heard it looks great.
http://www.testors.com/catalog_item.asp?itemNbr=1211
ALL PRODUCTS
http://www.testors.com/catalog_browse.asp?ictNbr=11
I found mine at Hobby Lobby, don’t remember seeing it at Hobbytown, bad thing is I asked at my LHS and they looked at me funny, could have been I was in my underwear [;)] Oh, that was a dream…
What is the use of it for rust? I haven’t heard of that?
dthurman,
Check out the link. Is that what I am looking for?
DRIPPING & PITTED RUST
Put a few drops of the Testors Cement where you want the PITTED rust. Before it dries use a dry brush and tab it into the rust power you want to use. You won’t believe what it looks like. They have that gritty, dry rust look. I read that on a link and it worked great. For a better look run the Testors in a small line, like a big scratch and do the same thing.
exactly the same stuff I have here, I used it to make windows in some of my metal vehicles also works great, also best window/glazing glue you can use.
Thanks for the tip on rust, I will have to try that. I weathers some cars with and air brush last night, but I am still liking the dry brush and chalk method, I guess until I get my airbrush skills down. Of course trying to control airbrushing on N scale cars is tough, even tougher when they are MicroTrain $30.00 cars [:O][banghead][censored]
Please look at the link I provided. If that is the stuff then I am going to order some. The weathering effect is outstanding. Glad I could help.
Awesome, hey its on ebay i may buy it off of there, now i can kick my weathering up another notch!
06,
Hey post the link so I can see it.
Thanks
8500HPGASTURBINE
Yes it’s the same stuff.
Here is a picture of mine, so I would say they are the same
Do you have the link to the testors and rust idea? I just tried it and I got so, so results, but that was just plowing into it. I can see it having some good merit. I wonder if this is similar to using hairspray?
BTW Great weathering tip.
Just scroll down to “The Rust Effect”.
http://modeltrainsweathered.com/inspirationyard.htm
I’ve been using the technique for a while now.
Jerry
Thanks! He has to be the King of Weathering. Of course no offense to the MR forums weathering gang [tup]
