Place to run my Dash 9 live diesel
I am currently converting an Aristocraft Dash 9 (1:29th scale) to live diesel and will soon need a place to run it. Those of you familiar with diesels this large know that it requires a minimum of an 8 foot radius to operate. I live near the Richmond, Va area and would like to find a place within 2-3 hours of the Richmond area.
dont live in richmond but a live diesel? thats pretty cool!
Look up Jim Stapleton in Purcellville, VA. He hangs out over on MyLargeScale.com under the name “Dr. Rivet.” Here’s a link to photos and video from his fall steam-up. Purcellville’s a few minutes west of Leesburg, so I’m guessing a bit over 2 hours from Richmond.
Good luck with the project, and by all means post photos!!!
Later,
K
If yer ever to drive to my neck’a Da sand, WDW area, bring it along, mine are minimum 11.5 ft, I run double headed Dash 9’s and Mallet’s…
Byron C.
Thanks for the invite
and I will be posting pics soon
Thanks for the info, will be posting pics soon
HeavyFreight,
I have two SD45s that I want to double head and I am also looking for a place to run. I live in Fredericksburg, VA. so if you find a place to run let me know and I will do the same if I find a place.
Hello,
kstrong posted this to me earlier
Look up Jim Stapleton in Purcellville, VA. He hangs out over on MyLargeScale.com under the name “Dr. Rivet.” Here’s a link to photos and video from his fall steam-up. Purcellville’s a few minutes west of Leesburg.
Still wait’en ta see dem Photos…where day at…
Byron C.
Hello,
Trying to figure out how to add pictures from my desktop.
Ok,
It’s not much, but here is an initial photo of the engine mount,engine, throttle servo and generator.
Easy,NOT you can not add picture’s from your desktop directly to this fourm. You must use a web picture housting site. I use photobucket, one picture at a time. I have posted way to many picture’s on this site, so here’s one more
Dave
Thanks to altterrain and dwbeckett,
More photos to come. A gearbox, fuel tank and electronics are to be included in the next stages.
So what kinda motor is that? Diesel or that mixed R/C gas?
Toad
Toad,
This is an O.S. FS 30, 4 stroke engine. This engine is typically used in model airplanes, but some RC cars now use 4 strokes as well. This engine burns a mixed RC fuel (methanol and castor oil).
for more information on the motor you can go to www.towerhobbies.com
Let me know if you have more questions
Bryant
You going to vent the muffler at the stack?
Seeing it is a four stroke do you still have to do the glow plug thing? And if so how will you start it if the shell is down?
Toad
Toad,
Yes, I will run the exhaust to the stack. I plan on using the stock exhaust manifold and muffler that came with the engine. But I will run flexible hose from the muffler to the stack.
Yes, I will have to deal with the glow plug. I plan on starting it with the shell off, because I will have to connect a power source to the generator to get it to turn over the engine.
