I decided today on how to approach two of my locos. I’m interested in any comments and particularly questions about converting lights from bulb to LEDs and which sound file for a GP9.
First, the E6, which is an unused but 2004 (or so?) vintage DC Lifelike P2K, DC with DCC 8-pin plug. Alot based on what I’ve read in the forum, I ordered a LokSound Select 6-aux, which should fit within the frame indent behind the cab. As is often noted, in this case DC ready meant there’s an 8-pin plug, but not room for speakers ala another similar E6 I bought with DCC installed and dual speakers; i.e., different frame cutouts on the two. But two HiBass 1.1" 8-ohm speakers with enclosures which should fit where the rear frame indent occupies the lightboard which will be removed, wired in parallel for 4 ohms.
Anyway, I found there is not a perfect LokSound file for the twin 12-cylinder EMD 567s as there is a file for a single 12-cylinder, and two options for 16-cylinder 567s (non-turbo (supercharged/blown) and turbo), so I settled for the single 12. I can see why folks buy the LokSound programmer in case future files are available.
Here’s a key question…the E6 has two bulbs which light the headlight and Mars light and number boards. Seems I should change them to LEDs but don’t know how easily things disassemble there and what size and how to add LEDs to replace the bulbs. A photo follows here:
The second project will be a Genesis DCC Tsunami sound GP-9 with two problems; i.e., the headlight grain of wheat bulbs quit and the horn sound is so pathetic I’m gonna attack the sound. So I ordered a LokSound Direct Select that should easily replace
