The layout always needs more trees. I brought a bag of trees home some time ago and finally got around to planting them. My layout is foam board, the trees came with doody little molded plastic bases.
I discarded the molded plastic bases, and drilled the trunks to accept 1 inch finishing brads.
I held the trunks in a C clamp, and held the C clamp in my drill press vice.
Here is a small existing grove of trees on the layout.
Thanks Dave, I am contemplating another foam based exhibition layout so this is quite timely!
In a similar vein, for a previous exhibition layout with a removable back drop I had steel pins attached to the backdrop board, sitting in plastic cotton reel spools glued into the foam base. The backdrop “hid” a staging yard but made removal very easy for transporting between shows.
With one club show layout, it was a bit disarming for other exhibitors seeing a layout half picked up (4x5 ft) with one arm and I feel that the lightweight way is the way to go for many!
Looks good Dave. Since my foam base is 2" thick, I left the trunks longer, and used a sharpened wood dowel (pencil works as well), poked a hole, used tacky glue, and planted.
I have found that the easiest solution is to use a small section of aluminum tubing that fits over the nub on the bottom of the tree. Sometimes I have to file the diameter of nub down to fit snuggly in the tubing.
On my layout I have foam board on top of plywood. If the foam is thin than I drill down into the plywood about an 1/8 inch and make the tubing long enough to stick through the foam and into the plywood. If the foam is thicker then a one inch piece of aluminum in the foam is usually plenty long enough.
