plastic building corners
How does one make a 45 degree angle cut lengthwise along the edge of a plastic sheet for forming corner joints on model structures?
If the sheet is thin you may be better off overlaying one sheet with the other. If you really need the bevel try this: Get a 45 degree angle, like the square/angle part of a combination square. Place one edge down on the work surface, attach a piece of sandpaper to the work surface, and hold the sheet against the angle and sandpaper and sand to a 45. I havn’t tried this myself, but I’ve done something similar to get a 90 on thick kit building walls.
Hope this helps!
This subject was addressed in some detail not more than a month ago. Take a look back under earlier posts.
John
How does one access past posts?
TMan,
I’ve searched using the search function at the top left of the page.
Where it says “Entire Site” and has a drop down button, you can choose “Forum” to limit the search here.
Eric from Doylestown
