Plastic shell modification?
Hello,
So I have an IHC 2-8-0. Solid engine, but I just can’t get over the absurd boiler shell. I want to be able to modify it in some form, ideally remove the domes and smokebox door and add some brass detail parts in their place. I’ve seen some kitbash projects on these forums and others on similar engines (such as a Bachmann Consolidation) where one or both domes were removed. However, such projects conveniently never said how they did such removals. So how does one go about modifying or removing domes, details, etc. from a plastic steam locomotive shell? What kinds of tools and skills are needed?
[#welcome]
Not sure whether that loco is all plastic or has a die cast boiler insert for weight. Either way, they can be shaped with hand tools: razor saws, files, drills, etc. Takes a lot of patience, though, if it’s diecast metal.
Many folks will turn to their Dremel. With the right bits, it’ll dig right through that stuff.
In both cases, you’ll be working with a hard to hold item and sharptools. Be careful.
Hi, and [#welcome] too.
I have only made minor modifications to some steam boilers, one was a Tyco die-cast pacific from years ago.
My reason for replying was to suggest looking at some of the excellent results that one of the contributors here has accomplished, RDG Casey.
Perhaps he will chime in here with some hints. He has a link to his Flickr photo postings in his signature and you can see some of the results of his work there.
https://www.flickr.com/photos/60361449@N02/
Good Luck, Ed
Ed, if i’m not mistaken, I think that most of RDG Casey’s very nicely-done stuff is scratchbuilt on commercially available mechanisms, although that may be an option for the O.P.
I’m wondering what you find so absurd about the boiler, other than, perhaps, the second sand box near the cab. As far as I know, these locos have a plastic shell, so it shouldn’t be too big of a deal to remove that and close the hole with some sheet styrene.
To remove the dome, a razor saw or hacksaw will work or a utility knife, or a cut-off disc in a motor tool, or perhaps a coarse mill file.
Once the area has been cleaned-up, use .010" or ;015" thick sheet styrene to make a patch to close the hole - pre-curve it to roughly match that of the boiler’s interior, and cement it in place (inside the boiler) using solvent-type cement. With the hole closed, next you’ll need to make a filler to bring the exterior of that area up the the same level as the rest of the boiler. While many would choose body putty, a filler plug made from sheet styrene is a better choice, in my opinion. Depending on the boiler’s thickness, you may have to use more than one thickness to accomplish this.
To get the proper shape, place a small piece of paper over the area, then use a pencil, held as parallel as possible to the boiler, to rub around the opening. This will give you a fairly close approximation of the size and shape needed. Mark the rubbing to denote the front, then cut it from the sheet and use it as a pattern to transfer the shape to the sheet styrene.
Add as many layers as necessary to get the area flush with the original sur
Didn’t the IHC 2-8-0 use the same shell as the old Tyco “Chattenooga Choo Choo” train set loco, which in turn I seem to remember was a slightly stretched version of a USRA 0-6-0 boiler/cab casting.
If that is true maybe it is good news as those Tycos are practically given away at train shows and maybe for a few bucks you could find something to practice on.
Removing domes on plastic boilers – usually the dome is largely if not entirely hollow so it leaves a gap that has to be filled, and that can be tricky to get right. One guy I know filled the dome with plastic putty first so that when he cut it down and then filed it down to the level and contour of the boiler itself, he was eventually filing the putty. He didn’t claim it was easy or worked every time.
Dave Nelson
[#welcome] to the Model Railroader forums. Your first few posts are slowed by moderators before they are posted, but that will end soon enough. Please stick around with us.
To remove a steam dome or sand box I work from the inside of the boiler with a rotary rasp in a dremel tool to remove most of the dome. Then I carfully clean off what is left with X-Acto knife blades and files.
-Kevin
Dr. Wayne is correct, Casey’s boiler shells are rolled from sheet styrene and then various bits are cut out to clear common commercial mechanisms - IHC, Bachmann, P2K, etc. He did a clinic on it at the Reading Modelers Meet a few years ago and made it look super easy. He also had a display of most of his locos, they were all beautiful models, and most of the models he does aren’t available other than in brass.
I’ve kitbashed several Rivarossi steam locomotive shells using Xacto blades and my Dremel cutoff disks. They get easier the more you do.
This is a Rivarossi Cab Forward that I kitbashed into an AC-9.
The picture above shows the domes removed. The AC-9 has a streamline skyline, I chopped up Bachmann GS4 shells to make the AC-9 skyline. Both the AC-9 and the GS4s were made by Lima and used the same skyline.
Here is my blog link to the AC-9 kitbash project.
I agree.
My main thought was his skillful use of styrene and filler material — AKA Squadron putty — to achieve the end results that he aims for.
As Wayne points out, that may be a good option for the OP. I just thought that by seeing RDG Casey’s results would be an inspiration for him to start his project.
I’ve seen bargain “grab-bags” of boiler shells and mechanisms at train show swap meets at reasonable cost that would make good fodder for practice or “scratch-bashing” a decent locomotive.
Cheers! Ed
I scrutinized a very clear on-line picture of the IHC model, and a Tyco “Chattanooga choo choo” in hand. They very much appear to be the same boiler body. Plastic. I compared pictures of the USRA 0-8-0, (as I’m sure that D K Nelson meant to say) and yes, the Tyco comes out a bit longer in the wheel base and the boiler. Otherwise, the boiler proportions check out fine. And the sand domes look a lot like some of the variations in the book. (Model Railroader Cyclopedia Vol 1 Steam Locomotives)
Personally, I’ve always liked the overall proportions and look of this model. Whether Tyco or IHC. Some of the molded on details cry for replacement, but, I like to hope it would result in a decent model. Especially since I have one as a WIP project.[8D]
With more than 23,000 Consolidations having been built, some as late as into the '30s, ya wouldn’t have to go too far out on a limb to imagine this model came close to at least a small number of them out there.
Maybe give it another chance?
Dan
Hey everyone! Thanks for the replies! So it looks like I’ll have to invest in a few tools. A nail file and a reasonably dremel tool are first on the agenda-anything else y’all think I absolutely must have?
And another general question-how on earth does sheet styrene work? As in, how is it cut, formed, etc? Once in place, can it be re-formed? Can it deform or revert to flatness over time? (I’m newer to the hobby, can you tell? [:P] )
Hi Dr. Wayne! First off, let me say that your scratchbuilding work is incredible.
I am open to scratchbuilding boilers, if need be. Probably not with brass, but I can make do with other materials. A lot of 2-8-0s in particular don’t have tapered boilers, so
