pollyscale cleaner formula
I saw and printed out a homemade pollyscale airbrush cleaner, and have lost this b4 i even mixed some up. So HELP i need to make some of this , I am using the badger solution that is premixed butwould rather make my own so if you paint with pollyscale what do you use to clean theairbrush with along with distilled water
Tahnk You
For acrylic paint cleanup and thinning, I’ve been using a simple 80/20 mix of water/isopropl alcohol for years with excellent results. I have soft water (low mineral content) so I don’t even bother with distilled water. Some people use window washer fluid (without amonia). You can also use straight isopropl alcohol for clean up. There’s no need to pay for those small bottles of cleaner/thinner from Testors/Badger or Polyscale.
Ditto. 80/20 water alcohol. If the tip and cap get real gunked up, I soak them in Goo Gone or something like that. Then use a pipe cleaner.
