Hello,
I have Micro-Eng. Code 55 N Scale. I am ready to lay the track on my layout. I was wondering if I should spray the track before I lay it, or if I should spray it after I lay the track.
Thank you,
Mike
Hello,
Thank you,
Mike
How is this a HELP topic? HELP would usually mean you have trouble or an issue that you cant resolve…
The answer to your question is… yes.
David B
Hey Mike,
Usually best to spray it after you’ve laid it. Otherwise you may end up with “zebra stripes” on the rails going around curves.
Good luck!
Jim
Ahhhh, Thank you Jim!
mj
