With the larger layouts temporarily on hiatus, I am planning to keep my skills going on the workbench with a little something I’m hoping to make as a portable display layout
A 3’-0" square “micro” layout, a pizza layout by definition, utilizing the old xmas tree base layout I’ve had for a couple years now. The old plywood base with its hand bent rail will become the portable Borracho RR display, with handlayed track, blue foam “mountains” and a small town of very small, detailed structures climbing the hill over the track. It will have detachable legs and felt pads so it can either be freestanding or set on a tabletop. It will be based on a very small HOn30 micro-layout I built a while ago.
If it comes out like I hope it should be a nice draw where ever its set up…progress pics when I can [:D]
Some current pics
Overall view, ties are 3/8 x 1/4 basswood cut down, to be stained after placement. the tunnel portals are from the indoor layout.
Close up of track and ties, I’ll be using Micro Engineering 3/8" spikes and I will spike every tie, I have an Aristo track gauge and will use the max gauge setting as the ultra tight curve tends to need additional wiggle room for the wheels. Nothing is glued down except the corkbed; I’ll begin gluing down the ties tonight.
I have blue foam for my “mountain” and the portals need some reworking, but first comes track laying![:D]
John all the buildings are modified HO Woodland Scenics white metal building kits, that building you questioned is cobbled together from different parts left over from the original layout. There no real plan, I’ll try to sketch something for it.
The “x-mas tree base” was something I made from spare plywood and some 1x2s, and the track was hand bent down to the 36" radius using an el-cheepo home-made track bender from a back issue of GR a few years ago. Can’t remember what issue it was in.
And yes, the portals used popscycle sticks…although I’m going to have to use a bit of modeling putty to fill gaps when I rebend them down to fit this new layout and then repaint them.
All the ties are glued down and begun spiking outer rail down, its the guide rail, and the inner rail will be gauged off it once its down tightly. Spikes are Micro Engineering medium 3/8" long, and they go down very nicely. Pics to follow.
As usual…another cool project from Smoggy L.A. ! I love seeing the pics of course. Hand laid track…I’m impressed…haven’t tried that one myself. A layout that size would be a cool display no matter where you set up. Keep it up pal. Later eh…Brian.
Well I found that spiking a curve is a tricky business, just because it was in guage when you spiked down a rail at ties #R, S, & T doesnt mean the rails at ties #R, S, & T will STAY in guage when you spike down the rail at ties #X Y & Z.
Had to respike two short sections when the track guage pulled apart to create too wide a gauge in the track. Hopefully thats done now and I can finish up the track laying tonight.
Well lets see, its been about a year, maybe I should try to finish this stupid thing BEFORE this years BTS. I work better under pressure anyways…
I started building up the blue foam “hills” last week, getting near the top now, be ready to start carving the foam into rocks pretty quick here, lets see…
Vic, thought you already had finished it, guess I am seeing doubbles…[B)] And if your going to call it “a stupid thing” you can send it all to me! Engine and rolling stock too, you can have caboose. [:-^] I think my mom would like it much. [:D]
Scenery like this has never been a strong point for me, I’m a styrene butcher by trade. Blue foam is brand new to me, but if it works well I’m doing the indoor layout with it. Very light stuff, perfect for this type of layout
Really cool. Would be perfect to have on a a deck or porch. You can sit outside and relaxe. As soon as I get my outdoor layout set I am thinking about a small indoor set. You might have started something.
You have all these indoor layouts so Whens the outdoor layout coming???[:D]
Someone mentioned Garden RR had an article about building tunnel mouths. Does anyone have that link. I have to build some on my RR and not sure how to go about this.
Your pixes and info are very much appreciated. I never thought of the problem of laying curved track and keeping it ‘in gauge’. It’s little tidbits like that that are very welcome to me.
Why couldn’t one ‘notch out’ several pieces of say, 3/8 x 3/8" wood as ‘keepers’? The notches would be just the width of the rails (light press fit) and would lay over them as the gauging and nailing went on ahead. It seems like it’d help relieve the stress on the rail as it was spiked further up by distributing it across both rails. When they were pulled off, if one or two ‘hung’, it’d alert one to an area of possible problem. Or perhaps I’m drinking from a bad batch?
Two steps closer to benchwork up: old drafting table in trash and reject kitchen table cut to stock size and put aside to await The Day. (The day I can start building benchwork).
What you say could work, what I did was to spike down the outer rail, then using the gauge spike down the inner rail. I did this cause I figured the inner rail would be easier to adjust or trim off excess rail if needed.
