Post-War Tenders, A Confusing Subject
Good morning,
I have been looking for a really clean, no cracks #243W tender. In all of my searches the tender number has always been stamped on the tender sides toward the bottom and always under the “E” in Lionel. However, I recently discovered a @ 243W with the number stamped between the first and second row of rivets near the bottom of each side. When did Lionel begin stamping the 243W in this manner? I want to match the tender up with a very nice early 1953 #2037 but I want to be correct. Thanks for your help.
Steve
Are you just looking for a #243 tender, or a tender to fit the time period or your locomotive (1953)? The reference I have on tenders matches the 243 tender with 1960-1961 production locomotives. Here is a listing on the #2037 locomotive. It does not list the 243 tender, but lists other tenders for early production locomotives. My reference has the 6066T for the earliest production locomotives.
Larry
The Tandem associates web site lists a 6026T as the correct tender for the 1953 version of the 2037. The 1953 Lionel catalog lists the 6066T.
The other posts are correct that a 1953 issued 2037 could have come with a 6026W. The 6026W or T were issued in 1953. The 243W was issued in 1960-61, and the 233W was issued in 1961. So if you are looking to make a 1953 combination, you should be looking for a 6026, either T or W, depending on whether you want a whistle tender. The 1953 Set would have been 1511S, having the above stated combo.
The 1953 Lionel catalog lists set 1511S as having a 6066T tender. I don’t see any other offering of the 2037 in 1953.
