Posting photos via Photobucket
Can you upload the photos to Photobucket.com I am not familiar with Flicker. I use Photobucket, If you post a photo to some dedicated Album in Photobucket, be sure to give each photo a Title. When you click on the desired photo, there will be four options below th photo. Choose the bottom “IMG” option. When you click on it, the word “Copied” will appear momentarily. Thiis means that it has been copied to the Clipboard of your computer. If the photo is Thumbnail, instead of IMG below the photo, it may be that you see a small square below the photo that you see by clicking on it. Click on the square and the Url rectangle below it. The photo should have a blue border around it. Click on Edit on the upper Tool Bar and then on Copy. Go to the place where you want to Post the picture (Either as a Reply, or the start your own Thread). Type in the Text that you want, and then click on ctrlV. The lengthy Code will appear. Click on Post, and your Text and Photo will then appear at the end of the given Thread. If you have any typos, or wiah to delete a photo, return to the Edit (for the posted item), and use backspace to eliminate any errors. You can Edit, as many times as you desire. Bob
