A column in the current Trains mentions that UP and BNSF built the Joint Line, and then five years later CNW, backed by UP, built a line into the Basin. Then the first train ran.
So, why did it take five years to go from the completion of the Joint Line to the running of the first train?
And why was CNW the one to get there first? Why wasn’t it UP or BNSF?
Trains had a special issue on coal about 10 years ago. Among other things it contained an excellent article on the railroad history around the PRB coalfield.
As I recall, Northwestern was broke and had no real chance of building their own line into the coalfield, but they had submitted an application to do so anyway. Having also received a similar application from BN, the regulator (still the ICC at this time) called representatives from both railroads to DC and told them that they would approve only one application, not both. The representatives were then directed to an empty conference room and told to “work things out”. This meeting resulted in the Joint Line agreement between BN and CNW, UP was not in the picture at this point and I don’t believe they had applied to build into the coalfield.
BN then built the Joint Line in fairly short order and started running their trains on it right away, it was UP and CNW’s trains that did not run until later on.
BN had ready access to eastern Wyoming and was already serving some mines in the area, but Northwestern’s trains would have had to brave their ‘Cowboy Line’, hundreds of miles of decrepid pioneer-quality track with lots of 60 lb rail in order to reach Wyoming.
Northwestern considered upgrading this route, but ultimately struck a deal with UP to avoid this, giving all three railroads access to the joint line. The CNW/UP access came from the south, using a shorter section of new track to get to UP’s main route and almost completely avoid the Cowboy Line. This process took years, and BN tried to freeze CNW out of the Joint Line for missing a deadline that was in the original agreement, but the ICC ruled that clause to be anticompetitive and therefore illegal.
LO: All of the railroad in that country (BNSF/CB&Q plus the CNW Cowboy line were in crappy condition. CB&Q/BN had already drawn up abandonment docket paperwork. Crawford Hill and Belden Tunnel were a derailment a day nightmare in the beginning of the coal boom. SD70Dude got it partially right about the track condition, but the subgrade issues were far worse. CNW/DM&E used to suffer “standing derailments” where if you left a train parked on the main and came back later, parked cars would derail overnight in the soft expansive soils. Tons of money was wasted on band-aid solutions until what was to become the PRB Jointline was thoroughly rebuilt. (BN’s way of doing things would bite them multiple times over, they made money in spite of their blunders. CNW less so.)
Chadron (CNW) and Alliance (BN/CB&Q) dealt with all kinds of problems going from jerkwater to frontline status. (The alcohol and aspirin makers must have made a killing.) They crossed at Crawford, NE and CNW split at Dakota Jcn outside Chadron.
Sorry, I hope you didn’t feel I was being snarky. That wasn’t my intention. The Chicago, Burlington & Quincy> later Burlington Northern> later BNSF built through the area a long time ago. I lived in Gillette Wyoming in the early 80’s. It’s the only real city in the PRB. The BNSF runs right through the middle of town. It was a big deal when they built and overpass for vehicle traffic.
Related- when I lived there, the BN would crash a coal train about once a month. They were having seious problems with drugs and alcohol at the time.
The bad soil Mudchicken talks about was refered to as clay expansive soil- think bentonite. In the town of Wright, south of Gillette, it was common back then to build houses with wood basement floors because the soil was so weird it would break up a concrete floors.
While the CB&Q, GN and NP were separate companies, they were commonly referred to a ‘The Hill Lines’ and the all danced to the tune set by James J Hill - The Empire Builder and Hill’s descendents. The formation of the corporation BN was more of a sanctification of what the Hill Lines had been doing all along than it was a actual merger.
The creation of BNSF from the merger of the BN and the ATSF was a infact merger.
Not so much. Although NP and GN did jointly own CB&Q and SP&S, and James J. Hill owned stock in both, they really did operate as two separate railroad entities. They had separate presidents and boards of directors, separate facilities etc. They didn’t really co-ordinate what they did anymore than any other two neighboring railroads.
They did share a headquarters building in downtown St. Paul…sort of. NP was on one side of the building and GN on the other. Each had their own entrance, and I believe the only doors between the two were on the first floor and on one of the upper floors - and the doors were usually kept locked.
I came off the NP as of the 1970 merger and was a clerk at Northtown (Minneapolis).
Three answers:
In St. Paul, the only door between the two railroads was the door between the president of the NP and the president of the GN.
The X-CBQ line through Alliance was in terrible shape and the CBQ knew it. The late Eldon Phillips was a CBQ man who said that the “new company” would have to rebuilt it and the BN had to build it up from the ground up, which they did. I can confirm that drugs and alcohol were a problem, what the adding of new employees to the railroad at that time. The Trainmaster and Road Foreman were over worked.
I can confirm that the BN had many terrible wrecks from 1970 to 1995 some where involving coal trains and some were not. Del Grosso’s book on “Locomotives of the Burlington Northern” lists 158 locomotives destroyed during the above time period—of that 100 were high horse power locomotives. A dispatcher error (I knew the fellow) caused a lap order into Motley, MN. Three good men were killed, one received a disability, and the conductor and rear brakeman (on the cabooses) were not injured. Six big locomotives were destroyed. I saw the scrap loaded into gons when I worked in the Material Department at Northtown Diesel Shop.
Although I have known for several years the significance of the PRB regarding coal and railroads, I didn’t know anything about the history. So I was intrigued when I saw that the current issue of Trains had an article about the PRB. Before I read the feature article (and I still haven’t yet) I noticed that Bill Stephens’ column was about the Basin. Since it was only one page, I decided to read it first.
These are, verbatim, the first two sentences of his third paragraph: “The Joint Line’s final spike was driven home on Oct. 6, 1979. Five years later and bankrolled by UP, Chicago & Northwestern built into the Basin and ran its first loaded train on Aug, 15, 1984.”
(During that time period, I was not paying attention to railroads at all.)
In his column, Stephens at that point jumped 19 years ahead in time; so those two quoted sentences comprised all I “knew” about the early history. A quick skim of the feature article seemed to show that it’s not about the history. I then went online and googled Powder River Basin railroad history, and got nothing of value; so I gave up.
Many of the answers you seek about the timing of construction are in the various segments on the map that appears with the column. But I can understand, given the shorthand version of history in those two paragraphs, how you could have questions.
Burlington Northern began building what became the Joint Line in 1972. It began as a 15-mile spur off the main line that runs from Alliance, Neb., to Billings, Mont. The spur, which began at Donkey Creek Junction near Gillette, reached the Belle Ayr mine, the first to open in the Southern Powder River Basin. Work progressed southward as more mines opened. Chicago & North Western also eyed the coal fields, but its most direct route was a ramshackle 519-mile branch across Nebraska that would require rebuilding at more than $1 million per mile. It wasn’t until 1980 that CNW arranged financing, backed by UP, for a cheaper alternative: Building a brand new 56-mile line from the UP at Joyce, Neb., to its own Chadron, Neb.-Casper, Wyo., route at a spot called Crandall, Wyo. West from Crandall, CNW had to totally rebuild 45 miles of its existing route to handle heavy coal traffic. And it had to build the the brand new 6-mile Shawnee Cutoff to reach the Joint Line at Shawnee Junction.
There were some legal squabbles between BN and CNW, along with delays related to environmental issues. Thus CNW did not begin construction until 1982
