I recently read “Done In a Day” by Pele Solleberg. He mentions using powdered chalk as part of his weathing techniques. I’ve done a Google search, and have had no luck. If someone could point me in the right direction, I’d be most greatful. Thanks
I went to a craft store and bought normal pastel chalk. I use 150 grit sand paper to turn it into a fine dust and go from there. It works pretty good, but I cannot get the rust color I was looking for.
Do a search for “weathering chalk” and you should have more success. The chalks typically come in sticks - I drag a hobby knife blade along the stick and collect the dust on a piece of card.
I doubt if it is available ready-made. Everybody I know that uses it makes their own. I use a coarse file to shave pastels down. Try a craft store for pastel chalks, and make your own. Less messy to handle and store.
Another source for pastels is a full service art supply store…the one I shop at has pastels in over a hundred colors. Once you have “powdered” them you can mix powders. Also most will mix with water to make washes
I too, use the hobby knife scrapping to make my powder
I prefer/use “sticky” chalks like Bragdon makes. Unless the model is frequently handled, the chalk holds well without applying a clear coat and the resulting near disappearance of the chalk.
I used to use powered chalk but the supply here is so poor that getting the right colors is hit and miss, so now I use AIM weathering powder that I get from Walthers.
I use a brand of chalk manufactured by the Nobody Remembers My Name Chalk Company.
About fifteen years ago a local art supply store which had been in the same location for about 35 years was in the process of relocating. Someone found two boxes of chalk in the storeroom; this chalk was obviously not of the currently carried brands and no one employed there at the time could remember where they had come from. The labels were obliterated with age hence the Nobody Remembers My Name label.
They were just putting them out on the discount table for four bits a box; I had never used chalk for weathering before but I sure couldn’t pass up the price. I ground them up in a brand-spankin’-new electric pencil sharpener and stored the powder in small jars. They have served me well over the years although obviously I have used some colors more readily than others. I took one stick each of red, yellow, and blue to render a brown which I use as a dirt and rust base. Before use I grind them into a very, very fine powder in a mortar pestal(sic) and make a paste with alcohol which I drybrush onto my stock. I have found it necessary to seal my cars and structures with a clear coating to avoid smearing.
Do yourself a favor and buy the ready made pack from A.I.M. or Bragdon powders. I bought an 8 pack A.I.M. from walthers catalog. It is superior to the chalk sticks you buy at the hobby store and have to shave with a file. I know from experience.
You can get powdered charcoal at the local art supply shop, but generally the chalks used for weathering are either in stick form at the art shop, or in little plastic cubes at the local hobby shop. (You want to use a oil-based chalk…not the chalk you use on a chalkboard.) A lot of times a fairly stiff brush will be able to get the color off without having to scrape it. Powdered charcoal is good for giving an overall dirty patina to a model, then you can use chalks of red, gray etc. for weathering specific to the car (like say rusty red on an iron ore car).
stix, you raise a good point about oil-bassed chalk as opposed to the type used on chalkboards. I have always felt that chalkboard-type chalk is what I got back in the early '90s and it is much too dry to use without some sort of moisture to assist in it adhering to surfaces; this is why that I have found it necessaary to make a paste before applying weathering to structures.
On the trucks, I started by adding a drop of water to some brown powder and sorta painting that on, then followed with different shades of rust and gray powders and finished off highlighting the journals and stuff with black powder. Interestingly, with the Bragdon powders you can get different effects by varying the pressure while rubbing the powder in.
