Power feed
Hi guys, its me again. I just wanted to ask a question. I was running my new MTH hudson and noticed that the locomotive seems to loose power at some parts of the track. I was told that in order to solve this problem I have to add another feed at least tot the other end of the track or where it looses juice. Now my question is, how much feed can I put since I am only using one Z1000 transformer? I tried adding one feed on the other side and I see that it helped. But I still have some week spots. My layout is just an oval roughly 18 by 8.
Just for the heck of it I would add two more, essentially placing one 1/4 of the total track length apart. Depending on what type of track you are using the cost of additional connections is very little. Hope this helps.
Thank you for the reply. I am currently using fastrak from Lionel as of now but will be switching to Gargraves as soon as my benchwork is done.
The rule of thumb I use is to have a power feed every 6-10 sections of track. That way, the engine is no more than 30-50 inches from a feed. I also added extra feeds where I have back to back switches(like yards & crossovers). Gargraves sells power connectors that slip into the rail from underneath, they make a pretty good connection. I’m using Ross track on my new layout, and may use a homemade version of them, If I don’t solder to the rails–
How many feeders you have has nothing to do with having one transformer. You can have as many as you need. I recommend using no smaller than 14 AWG wire, which you can find in a variety of colors at any home-improvement store. Stranded or not stranded makes no electrical difference and is purely a matter of convenience. You don’t need to run a separate pair of wires for each feeder. You can run a single pair around the layout and tap into it wherever needed. You can use a few inches of smaller wire for the taps if that is easier than connecting 14 AWG to the track.
Bob, This is very helpful, thank you very much. The very first thing I did was run separate wires. What a pain that was. glen
My layout is wired exactly as Bob described. I use this to tap the feeder wires into the main power wires. Of course, I keep mine red to red and black to black unlike the picture below.
Wire Tap-In Squeeze Connectors (10-Pack)
I call them suit case taps but they are called Wire Taps . I have yet to have one go bad on the layout or the boat trailer. On the boat trailer they are submerged occasionally, too.
