Now for my second question: Anyone using Tortoise to power route frogs? If so, how? Or does anyone have any better ideas? Thanks.
The instructions that come with the Tortoise tells how to do it. Essentially you connect one of the 8 Tortoise contact points to your frog. #1 and #8 are for CD power, so you can use #2, #3 and #4 for power routing. I think 2 and 4 are for track power + and -, 3 gets wired to your frog. You can use the other set of open contacts to switch a lineside signal. If you wire bi-color red and green LEDs in series with the wire going to frog, you can get track color positioning indication that you can mount in a control panel or the layout fascia.
If you want to go the non-Tortoise route, you can use a SPDT slide switch. Power in on one end, power out on the other, the frog connected to the center stud. Connect the track switch to the slide switch with a metal connecting bar.
Posterboy - Kato has turnouts with switches which allow you to change the frog from powered to non-powered just by flipping the switch (all prewired inside turnout). But this is only available on their Unitrak which has roadbed built-in and I believe is incompatible with tortoise machines.
Here’s a wiring diagram from Tony’s:
http://www.tonystrains.com/technews/tortoise/signal-wiring.htm
Not only the frogs but lights also. there is a Diagram from Tony’s that will show you how to use an LED without needing a resistor to protect it. I was NOT a big Tortise person but now I think that they are more than worth the over price they are.
If you want a REAL temptation look at the HARE II it is the way to go if you can swing the $29.95 times how many you need.
Take Care
I use the HARE, never tried it without a HARE. Very simple, Very Easy, I love the HARE. I agree it is a little pricey, but I am using them for the advanced features, so it is worth it to me.
Original Hare or the Hare II? I need 96 of them if I go that route. I have a digitraz DS52 for the crossovers but wa thinking about the Hair II fior the others.
Taker Care
George P.
