I have been model railroading for several years now and would like to start sctatchbuilding structures out of wood and or styrene. For this type of material would a power saw be of use and if so what type? Scroll saw, table saw or a small band saw? Any hints on whats worked best for you? Thanks.
Scroll saw or small band saw. I’d personally go with the band saw, because you can do resawing with the proper attachments and cut some pretty tight turns with practice.
Adam:
A scroll saw will allow you precise cuts. It’s also easier to use than the bigger saws you name in your question.
Gordon
Without a doubt,the scroll saw is the choice although a band saw is a fine tool also.However I recommend that you purchase a “middle range” saw so that you get reasonable quality at still a reasonable price.If you buy too small you will be very limited as to the pieces it will allow you to rotate for one thing and the cheaper ones lack power to cut thicker pieces.
I own a Delta 16 in. scroll saw with which I’ve cut almost anything with,from 1/8 in. plywood to 3/4 in.,plexiglas and even aluminum parts and never had a problem in 6 years.Considering that I abuse it occasionally,I say it’s a fine tool.
Another suggestion is to always keep a good supply of blades of different types for it.I’ve found out that your last blade generally doesn’t last very long…
Adam:
Gordon
