I have 30 atlas under-table switch machines and plan to use them in a future layout when I retire (in 5 months, yay!). Ken Stapleton’s 751D turnout controls appear to be an excellent addition since each one has a built-in CDU and it is simple to add turnout indication using LED’s on a control panel. The layout will be in a 24’ x 12’ room, around the walls, and with a center peninsula. The total linear run is 85 feet. I plan to use walk around DCC control and have 7 to 10 small control panels.
My questions:
Power supply. Ken recommends using a linear 12Vdc 2A power supply. He further clarifies to use a conventional supply built with real iron and copper transformer (old school) and not the newfangled SMPS types. I can find PS’s if I search for linear 12Vdc 2A PS. How do I know if it is an old school PS? Can anyone give me a PS recommendation?
Wiring. Ken recommends using a 4-conductor 24 AWG telephone cable for wiring between the switch machine and the 751D switch control. However, he does not specify wiring from power supply around layout and the drops to each 751d. What size wire would you recommend for power supply (85 ft total run) and the drops?
LED color. The 751d is set up to control two LED’s. Is there any advantage for using the same color for both LED’s versus say red and green? Two colors makes great sense for crossovers but not sure if valuable for all turnouts. Anyone want to comment on their experiences with LED lights?
Control panel design. Each control panel will be very simple with maybe 3 to 5 turnouts. The layout will be a wood grid with 1"x 4" stock. The 751d
By an “old school” power supply, he means one that is a transfoemr, rectifier, adn filter capacitor. NOT a switching power supply. The problem is, they are getting harder to find. The reason he makes this recommendation is that when these all power up, there’s going to be considerable inrush current to charge up the capacitors. An old heavy iron transformer can handle a momentary overlaod liek that iwth no problem. A modern switching supply, especially a small wall wart type, will not. The sealed wall warts often have a section of fuse wire inside to shut them off if too much current is drawn, to make them safe. It’s not fixable, so if it blows, time for a new power supply.
With 30 of them, I would suggest multiple power supplies, 2A is not going to be happy when all 30 power on and try to charge up. Yopu also get this same inrush after switching one of the turnouts, but that will only be one unit at a time (unless multiple people are running trains).
There’s a bit of a dilemma here. Most any new power supply you get that says 12V regulated will be a switcher. An unregulated one might well be an actual transformer - but you need to watch the actual output voltage. An unregulated 12V power suppyl can put out significantly more than 12V as low loads (and once past the inrush of powering up, unless you are activley changing turnout positions, this circuit is going to be a very light load, even 30 of them). Ken seems to only use 16V capacitors, which is fine if the input is no more than 12V, that’s plenty of head room, but a power supply rated at 12V that puts out 16V at light load is going to potentially cause problems. So finding the right power supply is going to take a little hunting.
Using multiple power supplies will avoid having to run 85 feet of power wire to these things. #18 wire should be fine if you do this.
LED color is a personal preference. I like two different colors, one for the normal route
A suggestion given to me for which I am thankful was to run all wires – track connectors, switch machines, etc. – to connections right behind the fascia.
Wires can be dropped through holes in the table, and pulled over to the fascia. It really minimized time under the table. Any work on wiring can be done sitting in a chair rather than crawling around.
I like Ken’s product but it may be cheaper to just purchase a Circuitron snapper or two and figure out another method of controlling the LED’s. The layout will be narrow at 12 to 18 inches wide and mostly lone wolf operated. Turnout indication is a preference at the moment but necessarily a got to have.
Thanks John! Great suggestion! Do you have any pictures of your layout wiring. I’d like to see how you wired your layout! Wiring from comfort of a chair would be marvelous!
This is the only picture I have. I wired the lighting for some buildings with this set. Other sets are track wires or switch machine wires.
I bought the terminal strips online for just a couple of dollars, and the spades are very cheap at a hardware store.
The poster known as Lion gave me the idea of doing all wiring right behind the fascia.
If I ever need to make new connections or disconnect anything, I unscrew this section of fascia, and the terminal strips are right there. Be sure to label the wires. No more crawling under the table – I’m too old.
I got the terminal strip idea from MR’s “Salt Lake Route”:
Hmm, wouldn’t cost much to give this idea a try! OOPS, CAUGHT the problem, needs a momentary dpdt but that would not keep the led’s on.
Any limitations on number of turnouts or length of run with the circuitron snapper? Could be significantly cheaper than Ken’s excellent switch controls.
As a long time user of the Atlas #65 under layout switch machine I wouldn’t recommend using them. Over time the throw arm becomes week and they don’t cut the mustard. Driving them with a powerful CD power supply helps. When they start to fail to hold the rail points I’ve been replacing them with Peco PL-10s which requires a mod to the Atlas turnouts. I add a Peco type spring to hold the points firmly to the fixed rails.
I haven’t had any problems with my Mel kitbashed turnouts. They work better than a new Atlas #65.
I’m currently experimenting with SG90 servos. I think the future switch machines will be servo operated. A do it yourself servo switch machine costs under $3.
I’ve been too busy to try it yet but I want to mount the switch 3/4 inch below the turnout. The switch mounted from above so could be easily removed if needed. The throw arm is significantly stronger at 3/4 inch than at the maximum of 1 inch above the throw. We’ll see when I test it. I have the switch machines on hand so want to use if I can make them reliable.
Rick - that fancy power supply with the display is overkill. The other one would be fine, and since the highest setting is 12V, you wouldn’t have to worry about frying something if the selection accidently got changed.
I know you have them already, but I agree with Mel on using something other than the Atlas machines. I’ve using all servos on my new layout, used them on my last layout, too. Since quantities of Ken’s circuit come as kits, with one built as an example, I presume you are capable of some basic electronic assembly.
Mel - in that mounting scheme, are you just gluing the servo to the bottom? You do know you don’t have to stack that much styrene tubing, just lop the upper ear off the horn. I’m still trying to decide how to mount mine - I might just end up buyign a 3D printer and print my own. Friend of mine just Gorilla Glued his to the bottom of his plywood - I think I’d rather still have somethign that screws on. I used the Tam Valley mounts (their old plastic ones, not the new wood ones) on my old layout, but I only had a dozen turnouts on the whole thing. I’ve got more than that just in the yard on the new one. If I don’t 3D print, I need something I can mass produce. Maybe just a pair of hoolow beams, screw the servo to them, and then run a wood screw with a washer up through each one to screw to the layout.
The problem I have with the #65 is the flat arm in the switch machine, it becomes puny over time (25 years) and flexes. The amount of twist flex in the arm out of the switch machine is so much that it can’t fully move the round rod to the turnout. It twists enough that the position lock can’t keep the points against the rails.
My #65s are also ¾” below the turnout, ½” plywood and ¼” cork roadbed. They started failing at about 20 years and now at 30 years old I have had to replace 7 out of 21.
If old age failure (25 years) doesn’t bother you no problems. At 83 years old Changing an under layout switch machine is not doable. I installed my turnouts to be removed easily from the top and simply drill a large enough hole to drop the Mel kitbashed turnout in and go.
I have a grandson remove the old switch machines. My arthritis has got the better of me but when the pain gets better I have another bad #65 to replace.
Randy, I have developed some soldering skills using the soldering station you recommended! Thanks! However, I’m considering the purchase of fully assembled 751D’s, more expensive but worth it to me in time and potentially avoided problems. The layout would be built stages. So, my goto guy, are you thinking two or three of the Parts Express power supplies for thirty Atlas switch machines? I’ve tried reading articles on arduino controls but they just don’t click well for me. I need to recognize my limitations and go with what I’m comfortable doing, Ken’s 751d + LEDs would be my gold standard and microtoggles + circuitron snapper is the acceptable solution.
Mel, I appreciate your always excellent assistance, support, and friendship! I am 66 so with a 25-year failure point, I would be 91. With existing heart issues and Alzheimers on both sides of ancestors, 25 years is probably a long enough time frame! I am working on a way to mount the atlas from above. Will take pictures when I have time to try it out. I retire in 5 months with lots of things to wrap up so may be a month or two down the road…
3 would be good - 10 machines per. Those power supplies are cheap enough. If it ends up being more than you need, you can always use one of them to power structure lights.
Have you talked to Ken about supplying a quantity of assembled units? Likely he is a one man band and I suspect it will take him a while to build 30. It’s a pretty simple circuit, and I like the way he supplies one built to replicate - so if you make the others look exactly like the built one, it will work.
I did notice that there is no sort of terminal strip, you just solder thee wires to the board. So I doubt much heavier than what he recommends will work for any of them - however, for a short distance, within the panel, it’s fine to use the thinner wire for the power wires. Group all the ones in a panel together, prefereably in some sort of terminal strip, and then run something like #18 between the power supply and each panel.
I wonder if he made the spacing of the connection points to fit a standard screw terminal unit - you might want to ask that, if he did, he can probably give you a aprt number for that. You’d have to solder that on even if buying the built up units, but it would make connecting the wires for power, switch machine, and LEDs easier.
Randy, thank you for the thorough reply! I will confirm with Ken on the power supply. I have not yet talked with Ken about the total order. My thought is to buy 5 initially (4 assembled, 1 kit) and do a test of concept on a narrow module with a crossover and two turnouts. This enables a test of soldering my own 751D and the module allows testing my planned atlas installation method from above.
Ken sells LED’s and a wiring harness (8 pin header with 8 one foot long wires) for ease of installation and one-stop shopping. Definitely will purchase those!
Great suggestions on the panel and wiring! Based on your suggestion, I likely will use 5-way Wago connectors to distribute power to the 751d’s. The Wagos make strong quick connections, can handle 12 to 24 AWG wires, and are easily removed for use on the final layout. Wago’s can be ganged if I have more than four turnouts on the panel. Assuming I have 7 panels, each power leg would only have 7 connections for 30 turnouts.
Mel, my friend, no problem! I checked out your modified Atlas switch machine using Peco parts. Looks good, nice mod! Unfortunately, the parts (Peco PL-10) are very expensive on ebay at $9 to $12 each plus shipping. Couldn’t find any offers of multiple Pl-10’s. Take care!
Mel, in the thread below, you discussed your technique for your turnout indication circuit. Would your circuit work if the power supply was 12 vdc from a Circuitron snapper?
Yes. The relays I use are 5 volt latching dual coil and will work with any DC voltage from 5 volts up with the proper resistor.
The reason for 5 volt relays is for compatibility with Arduinos, and I found them readily available on eBay for a good price. Any latching relay would work. Paralleling the Atlas switch dual coil machine with a dual coil latching relay will work great.
The DS2E-ML-5VDC relays are available in 12 volt by changing the 5VDC to 12VDC then no resistor needed.
Rick just for comparison I have 27 of the 751D in use at the time and will be adding a few more I have a doz or so ready to go in a box I had a 12v 1amp wall wart at first but it just didn’t seem to work so went to a 12v 1.2 amp and works fine not sure if it a switching supply the 1 amp one was And if you get a power supply get a regulated one so the voltage stays at 12v So if adding the extra ones puts too much load on the one trans I will just add another one and split them They are easy to put together Ken gives great instructions Think it took me maybe an hour or so to do 10 of them I did use a home made snapper but I like these better mainly because of the built in led connections A few of my sw machines are the old Tru Scale ones way heavier then atlas
