Powerful Switch Machines
I’m using Atlas Code 100 Sectional Tracking with there standard Left and Righthand turnouts operated by their Under-The-Table Switch Machines. It seems that every since I added ballast to my track, the mechinisms don’t work properly. I have examined them from every which way. The pin does move back and forth as advertized, and when I jiggle the points back and forth with my finger they move pretty freely. However 1+1 does not equal 2 in this situation. The track is not nailed down too tightly, which was what I thought. My guess now is that, for some reason there is increased friction between the plastic part that connects the 2 points and and the cork roadbed beneath. I also think that the pin from the Switch Machine, being plastic, bends and refuses to maneuver the points. Is there anything I can do to fix the situation? Can anyone suggest a sturdy Switch Machine that can overcome the friction? At a local hobby, I saw Peco Brand Switch Machine made with all metal components, including a metal pin. Is this the way to go?
Any suggestions would be most appreciated. Thank You.
I assume that the turnouts worked fine before you added the ballast? If so, and considering your checking the movement of the turnout, then your problem is a common one. Never ever try to ballast the moving parts of a turnout. Never ever apply glue to ballast anywhere near a switch machine or turn out. If possible, remove the machine and cover the moving section of the turnout with tape before ballasting and glueing. It sounds like either a particle of ballast has gotten into the piston of the switch machine, or more likely, glue in the same place. If you are carefull, you can take the machine appart, wash it in war water, and reassemble it. However, it would be much easier to replace the machine and call it tuition for Model Railroading University. There is no nead to go to the more expensive machines if using Atla turnouts, and most will not work anyway as the Atlas turnouts have a long travel when compared to other brands. I use Atlas turnouts extensively, resorting to Peco for curved turnouts and I have never had a need for mor powerfull switch machines. However, I have managed to glue several in place, never to move again when I first started.
James H.
Gregory
It sounds like you mave have some glue under the throw bar of the turnout. This will reduce the clearance and make the throw bar drag which will not allow the switch maching to move the points.
BOB H Clarion, PA
