I recently completed a large loop, approximatly 70 linier feet in legnth. The largest transformer I have is a VW 150 watt. Without additional lock on it will move a test engine about ten feet beyond the lock on. All the track is new, including two 45 degree crossovers. I am limited in toy train electrical systems so here are a couple of questions:
Would a ZW 275 with extra lock ons possably move one train of medium legnth properly ? Would two VBW 150 in phase do it ? What other options might I consider ?
Any suggestions, instructions, or far out ideas will be most welcome ! Thanks/
I would add two or three more lockons equidistant from each other and see how that works first. And you can wire one from the other. Also make sure the connections between each track section are tight and secure, even with new track.
I think you might be having another problem there as I have a loop that is 16’ x 14’ so my loop is about 60’ and I use just one lock-on ( yes I know I really need more) and I run 2 dual motor engine pulling 8 18" lighted passenger cars and a boxcar with no problem. Now I do use a zw but then again its mainly because of running 2 dual motors and all the lights in the passenger cars. I have run single motor engines on it and they fly around the track the dual will to actually. If your engine will only go about 10’ feet you have some serious connection problems I would think. Something just doesn’t sound right to me as my train is over 20’ in legnth and I have no problem with just one lock on. I’am using gargraves track but I haven’t done any soldering of joints yet or adding jumpers between connections.
You didn’t mention if this is a permanent arrangment on a layout table, or not. If it is you might consider a wiring “bus”. A bus is a long length of heavy guage wire that parallels the track under the table. Every couple of yards or so you solder smaller guage feeder wires off of the bus and run them up through the table top to the track connectors.
The electricity then mainly travels through the wire, rather than the track, as it is the path of least resistance. Of course if you wish to isolate a section of track, you don’t connect it to the bus. Rather you have to provide a separate wiring path for that section.
OK ! PROBLEM LOCATED !! When I got hold of a tester tjhat would help me trace track voltage, AND someone who knew how to use it we located the problem. A new 40" section or track was the culpret. O mid-location cross tie had no insulation and stopped the whole circut. After changing that section a test train traversed the whole 80’ atspeed setting on a good ZW 275 transformer.
Thanks to all who responded with sugestions and input.
