I am considering powering the frog on Atlas Customline Mark 4 turnouts. The turnouts are already in place and ballasted. Can I use solder on this type of metal?
Not really. Atlas frogs use a pot metal that does not readily accept solder. If you have access to a plating machine (like the one Micro Mark sells), you can apply something like copper plating to the metal that takes solder. Otherwise, use the screw hole cast into the frog and attach a feeder with a 2-56 screw.
That is the way to do it on Atlas metal frogs.
2-56 will break the hole out. Use a 1-72. Ho-Bits and others have small brass screws. Use a very short one with the smallest head, since it will all be visible on top, carefully screw it in the hole (the pot metal is even softer than brass so it will self tap just fine). Drill a hole next to hit and run the feeder wire down, solder the top to the brass screw, then paint the whole thing flat black to hide it as much as possible. Slightly more complicated, but at least the visible remains wouldn’t obviously be a screw head, use a slightly longer screw, drive it in a few turns, then cut the head off just slightly above the frog surface with a cutoff wheel. Solder the wire to the screw stub and then paint it flat black.
The hole is designed to be tapped for either a 2-56 or 2mm thread, I went with 2mm only because I have hundreds of metric screws in stock.
Mel
My Model Railroad
Bakersfield, California
When I power my Atlas turnouts, I use the screws as mentioned. But rather than solder to the screw, I cut a piece of .020 brass shim wide enough to get a hole in to fit the screw, and solder it to the power wire. then just put it together and tighten. Have Fun!
Thanks to everyone for the replies.
Guy,
A couple yrs. ago I was having a little trouble with a crossover…two #6 Atlas that went into a small yard, had a little bit of a stall at very low speeds with 4-axle switchers…so I needed to power both the frogs…they were already ballasted, so taking them out was not an option. I drilled a hole straight down the hole that is on the side of the frog from the top inserted a solid #26 copper insulated wire down the hole, stripped about a 1/4’’ of insulation from the end and made a 90 degree bend in it so when inserted in the hole the bend about 1/16 would rest on the outside of the hole and used the black 1-72 machine screw that used to come with the turnouts and was able to thread it right into the frog hole with the wire…just painted the head flat black and you would never know it was there. Just connected the wire to the relay that already was there for control panel lights and works like a charm. Since then, I have also done some #4’s exactly the same way, they were also already ballasted. My layout is 1/2 ply + 1/2 Homasote for roadbed and yards.
Take Care! [:D]
Frank
There seems to be some confusion about what size of machine screw to use. One can tap for a 2-56, but do not blame me when it either breaks as you are tapping the hole, or it cracks later on. Tapping for a 1-72 is the way to go. What you want to use is a 1/8" brass 1-72 screw(much easier to solder to than the stainless steel screws). If this is an ‘after the track is laid’ install, use a ‘slotted’ screw head. You can ‘tin’ the slot and solder your wire into the slot. I am using 1/8". slotted 1-72 brass screws. I ‘prep’ each turnout with a frog feeder(grey wire) and a red or black wire on each stock rail(to the DCC bus under the bench work). I also solder ‘braids’ across the hinge from the points to the closure rail. I strip out strands and make the braids for 3 strands of wire. Once the track is painted, the braids just vanish into the trackwork. The above listed modifications do wonders in assisting locomotives from ‘stalling’ as they go through yard trackwork.
Jim
I knew I wasn’t losing my mind THAT much. Yes, 1-72 is the size for the Atlas frog.
That’s the reason they used to come with them…along with a brass tapped bar for powering the frog. The underside of the turnout, has a notched tie where the hole in the frog is…you slid the brass bar in the notch and used the 1-72 machine from the top and screwed it into the brass bar. Easy to hide the screw head, with a little ballast or paint and it will work just as well, how I explained above…simple and easy…no soldering involved. The machine screw is hardened metal, so it will tap itself into the softer copper/brass wire and pot metal frog. I don’t know why they stopped putting those items in the turnout packages.
Take Care! [:D]
Frank
BTW: I have not even tried to conceal the screw head on this #4 turnout yet!
I was under the impression that the brass bar and other accessories came with the Snap Relay, so that you could hook it up for frog power. A number of years ago, someone discovered that Atlas would sell you just the screw and bar as spare parts. Mine were all prepared ahead of time before placing them, so my screws are underneath and invisible - but then I never hooked any of them up because I had no problems with any of my locos stalling. Just a bunch of green wires hanging down under my layout.
I wish I knew better. I wouldn’t mind to see a bunch of wire hanging free under my layout, whichever color they were.
Jim I tapped all of my Atlas turnouts for 2mm screws and none of them have cracked. I used a 2mm brass washer to solder the wires to as a ring type connector. After the screw was tightened I used my Xuron cutters to nip off the end of the screw then a cutoff disk in my Dremel to flush them to the top of the frog/tie. A dab of tie brown and they’re impossible to see.
Mel
My Model Railroad
2mm is dead between a 2- and 1-, so it worked. But a 2-56 is too big around. A 2-56 if available in exact metric sizes would be 2.184mm. A 1-72 tap probably wouldn;t cut much of a usable thread (I never bothered trying), but forcing in a 1-72 screw and making it self tap fits plenty tight.
Great info thank you. FrankG
Necro thread. Nothing new is going on with Atlas turnouts and 1-72 screws.
