Has anyone tried the method linked below to power your turnouts? If so, how did it turn out? I’m new to model railroading and exploring inexpensive ways to power turnouts.
I’m currently experimenting with SG90 servos (eBay $1.50) to operate my turnouts. The SG90 has plenty of power and the price is right. The trick is to keep the motor current low enough so the motor isn’t damaged.
The servo can draw as much as 100ma at 5 volts depending on the load. The motor gets hot at a constant 35ma. The servo motors drift with pressure against the throw arm without power applied.
Mel
Yeah, that was my question. I guess the motors would constantly be in stall mode, correct? Don’t see how that wouldn’t damage them. Also, would they buzz and be noisy in stall mode? Keep me updated on how it goes for you. If it works, I would like to do the same thing. $1.50 for the servos is great.
I didn’t go into detail of the severo operation. It takes 50 ma for movement and as high as 80ma to operate a micro switch. The motor gets hot at well under stall so the motor can’t be used in stall mode or the motor will be a goner in short order.
By using micro switches the servos will work OK but that requires some construction and dinking around with as well as running up the cost. For proper operation the SG90 servos will require in the vicinity of 80 to 90ma during movement to operate the turnout and micro switches.
One of my experiments has been using an Arduino to control the servos but I’ve still run into the high idle current problem. Constant high current means motor failure.
I haven’t given up yet, I still plan on using servos to operate my turnouts.
Do NOT do what that article had, servos just aren’t made to stall constantly. You need a proper controller. However, it’s easy to make your own controller. There is a series of articles on MRH by Geoff Bunza on using Arduinos for simple (and very cheap) servo controllers. The article explains all the information you need, you don;t need to knwo how to program, or even wire circuits, just follow the instructions and use the code provided. Mel and I are both workign on our own designs, mine’s a little fancy with relays to controlt he frog power and all. I have no plans to sell anything, this is a hobby, not a business, but everything I design will be freely available under open source license - both hardware and software, so anyone who wants to will be able to have PC boards made and buy the parts and put them together, and then load my program and go. There are also commercial options available, on my previous layout I used Tam Valley’s controllers for my servos (so this will be my second layout with Servos - I will not go back to Tortoises, and many of those new Tortoise competitors that work the same way draw far more curren than a Tortoise, which takes away one of the side benefits of the Tortoise, being able to wire some LEDs in series with the motor to indicate position, keeping the contacts free for other purposes.). The servos themselves are under $2 each. There are a million and a half ways to attach them to the turnout throwbar. The best option I’ve seen so far is a nifty mnount made for boats, unlike many of the ones that are 3D printed plastic or cast resin, it’s METAL yet only about $2.50 each. There are many DIY methods, one uses some aluminum channel that happens to be the same with as the 9G servos, so I guess that would be an even cheaper option.
I wasn;t totally sold until i bought by first controller and tried it out. After that I immediately ordered the rest to finish my old layout, and I am totally sold. It’s just about the least expensive way
Randy are you using the Tower Pro SG90 servos? I bought 20 of them off eBay and their quality control leaves a lot to be desired, but for $1.41 each I guess I can’t expect much.
They all have one thing in common, any pressure against the throw arm draws high current. With out a load the servo works great, with as little as 2 grams of back pressure against the arm it raises the idle current 15ma and higher. If I remove the data control to the servo the idle current drops to 9 to 12ma.
The motors get very hot (30 to 35ma) with constant pressure with the data control attached.
I bought a Turnigy Servo Tester for checking out the servos, all my test have been using it at 5 volts.
Yes, I have a couple dozen of them. On my old layout I tuned each Singlet controller so there was no buzz, and they didn’t get hot. I know when I am testing them on the bench I can get them to spike my bench supply to 1 amp if I grab hold of it while it is trying to turn.
If you look at most of the mouting schemes, they typically use an over-center action, so the servo just has to move far enough to get past the center point, and the geoetry of the wire then serves to hold the points without applying back pressude to the servo - and quite the opposite of Trotoises, you cna use much thinner piano wire, the idea being that it is stiff enough to push the points (and my sample tests are being done with unmodified Pecos - so they still have the point spring in them - I will probbaly remove those for th eactual layout) but then bend once the point hits the stock rail with some bending force less than the servo’s capability - so the wire bends instead of the servo stalling. It take very little pressure to hold the points closed.
I’ve noticed there is a pretty wide variation in the amount of travel from 0 to 180 on the servo library, some won;t go all the way to 0 and just stall and draw high power, likewise at the 180 end. So I just set my limits well back. I forget which size piano wire is on my samples, but it’s strong enough to overcome the Peco spring just a little past half throw, the rest of the distance is just bending the wire.
Thanks Randy. That what I thought when I read that article. A servo in constant stall mode can not be good. I will look at the Tam Valley controllers, and also read the Bunza article you mentioned, and then decide which direction to go.
I find it quite interesting as I read the various posts on this forum, particularly in regards to how we allocate and account for our hobby dollars. You gents seem (and that is certainly okay) pleased to have found one economical way to power your turnouts, albeit after some “tweaking” here and there. I prefer the relative security of known devices. On powered turnouts I use the Tortoise machines which I can install in a matter of minutes but at a higher dollar cost. Part of the wonder of the hobby.
There’s no more tweaking involved with a servo than with a Tortoise. Physical install is practically identical. Music wire actuator up through a hole under the throwbar. The fancy Tam Valley controllers do all the limit setting themselves, and like a Tortoise, once installed they tend to not go out of adjustment. Also handy in double deck situations since a servo is a fraction the size of a Tortoise.
With more than 100 powered turnouts planned, even saving $10 per turnout becomes a significant cost savings. As it so happens, in putting together the BOM for my circuit design, it comes out to about $10 per turnout all together, but that includes the buttons and lights. That is for the one with provisions for remote control and remote lockout via a CMRI type control system. Ones for yard turnouts and so forth save about $2 per unit, $1 per turnout by leaving off components that aren’t needed - the most expensive of which is the stinking connector. A 1 cent each I’ll probbaly just leave the 4 resistors I could eliminate just so the unused inputs to the micro are pulled up and not floating.
I’m cheap elsewhere too - using caulk to lay the track, a $1.19 tube is enough caulk for about 100 linear feet of track AND roadbed. And biggest savings of all, very few of my locos cost over $40, and that’s for P2K, Atlas, Bowser level stuff. I am VERY patient with eBay. Even the more expensive ones I have - never paid more than about half price for things like PCM T-1’s or an Atlas Gold Trainmaster.
I used the SG90 motors with Peco code 83 turnouts and momentary contact push buttons directly wired to the motors. With the Peco over center spring you do not need constant torque on the motor. I believe that I used two 9V power supplies. One button is +9V the other -9V.
Test the motor beforehand. The throw distance is approximately 180 degrees. Set the actuator arm about halfway through the throw motion. This way the motor will not be actuated to its limits when throwing the points.
I intertwined piano wire(use a heavier gauge wire) through two holes in the plastic actuator arm. This way the throw arm and actuating wire rotate together to actuate the points. I used two sided tape to stick to bottom of layout. So far they seem to work pretty good. Make sure surface is clean before sticking to bottom of layout.
That works great with Pico turnouts, unfortunately I have 18 Atlas Custom Line turnouts. I converted an Atlas turnout to Pico type a couple of years ago and it also works great.
I prefer the Pico snap spring over the Atlas anyway but removing and reinstalling 18 turnouts would be too much for my 80 years old body.
Insolently the Pico mod to a Custom Line turnout works very good.
Randy: I did not mean in any way shape or from to imply that you are “cheap”. I actually think what you are doing is not only economical but is also valuable to us all as we look for ways to enhance our enjoyment of this (or another) hobby. I am sorry if my post offended you.
I’m not offended - I’m the one who called myself cheap, because I AM cheap. I’m a PA Dutchman. Like my prototype railroad, we are notoriously frugal. Except maybe my car, but then again, by buying it used for half the price it was new, I get to drive a much nicer car than I could otherwise afford.
Here’s a short video of the units I described above in operation. Again these are with Peco code 83 turnouts.
By the way, Peco sells an adaptor that will allow allow other turnouts to lock in place. Not sure if they’ll work with Atlas but it may be worth looking into.
Yup, and I don’t care if people think I’m snooty because of it. Or other words which typically get assigned to drivers of my brand, which are not fit to post here. Too bad, it’s a great car to drive and even just driving the 2-3 miles to work it puts a smile on my face.
I read the article by Geoff Bunza that Randy mentioned above about building a DCC decoder that will control up to 17 servos. That’s what I would like to do. The article is here:
My question is this though: I plan to use the NCE Powercab DCC system. I assume this DCC decoder would accept input from the NCE Powercab and each servo would be connected to the decoder. I would prefer though to control the servos from a control panel with pushbuttons or toggle switches. And maybe control them from the Powercab controller also if I wish to. Can this be done? If so, would I have to get some sort of add-on to the NCE system like the NCE 524230 Mini-Panel Control for DCC Decoders?
