Anybody know if my present 2 brick (180 watts ea) and 400 watt tcp system will work with the new Legacy control unit I’m about to order? Is it a matter of just hooking the wires up and taking a couple of night courses to learn how to operate it - (no big deal)? I hope I don’t have to do any big changes.
Everything should work just fine! The Legacy Command Base attaches to the outside rail of your track system with ONE WIRE. The Base then gets plugged into your properly grounded outlet.
Real easy to install. Now, manual is not in “English”. No, some sections are easy to understand and then some are incomplete. If you have TMCC now, you have to disconnect the common going to the old command base and reconnect it to the Legacy base. Will not work with both connected. Not in the book. The Y cable with the unit will connect old command base to system. It will also mate with your TPC cable. Run TPC in CAB1 mode from Legacy remote.
Chief, the manual is in English. Some parts are left out so us Southerners cant figure out the system in all its componets and use it to launch a mass invasion of the North. [(-D] [:o]
