Pressing new axle bearing into 2333 chassis help.
I am installing new axle bearings into my 2333 chassis. I have the proper tools and such, but am puzzled as to why the bearings become too tight on the axles when they are pressed in. Even when only doing the first side, the axle doesn’t want to pass through it anymore freely. I have one here that I did both sides and installed the drive gear, and its too tight as well. I installed one, pressed the axle into the drive gear and centered it, then installed the other wheel bearing as the book says to. Then could barely turn the axle. How do I fix this problem? Cw or Bob?
Roger
Bearings like these, actually a bushing are normally reamed after pressing to restore the correct diameter for the shaft.
I understand that, but you cannot do that with F3 bearings. You have to install one side first, then push the axle through the gear and into that bearing, then install the other bearing over the exposed axle. You cannot ream the bearings and then punch an axle through them as the part that holds the gear will damage the bearing.
Roger
It sounds like the bearing is a bit oversize for the hole and is getting squeezed shut a bit when it is pressed in. It should not take too much pressure to install the bearing. There are issues with aftermarket bearings not fitting properly, so you may want to try getting bearings from another supplier to see if they fit better. If you have a micrometer, measure the O.D.of the original bearings, and compare to the replacements. The measurement needs to be exact, as even a half thousandths of an inch larger will make for a tighter fit, thus distorting the axle hole.
In the end, you may need to install the bearings first and ream them to size if necessary. Install the axle through one reamed bearing, through the worm wheel and out the other bearing. You may need to lightly hammer the spline on the axle through the first bearing. Do not worry about the spline on the axle damaging the bearing, as it will just scratch it at the most.
Larry
My bearings came from a company that sells old lionel, flyer and some other parts. They claimed these were OEM bearings. The bearings would easily pass an axle before installing, then not after pressing in. I don’t have a micrometer here yet, need to get one. It appears that one side of the axles is thicker than the other side.
Rob
While I have not had this problem on 2333, I have run into similar problems installing bearings in other places. To avoid the issue, I like to put the shank of an appropriately size dril bit in the hole to keep it open. Obviously, if you follow recommended practice, you could only do this on one side.
I agree with TrainLarry, you can push the axle through the bearing. I’ve done it, and I do not think the minor scoring that is created by the knurled section is anything to worry about.
I would try to always push the axle through the same side, and with the knurling in the same position. You should be able to feel the ridges of the axle catch in the tiny grooves cut into the bearing.
I am always interested in reading the solutions other folks have.
Cw, the fist one I installed I did have the axle sitting in it to help with alignment and the axle was stuck afterward. I guess installing both bearings and then reaming them out is the best solution. A 3/16 drill bit seems to be near perfect for this.
Roger
Roger, If you don’t have a Harbor Freight near you what about ordering an appropriate sized reamer on-line or even checking out Amazon, Micro-Mark etc. Granted it will delay your project a few days but the accuracy of the reamer vs a drill bit could make it worth the wait. [2c]
If I had any 2333 axles or bearing on hand, I’d be glad to check, but unfortunately, I do not.
The holes in bearings / bushing have to be slightly larger than the shaft that rotates in the hole, otherwise it will bind, as yours is doing. For example, I measured a NOS 2343 axle to be .3085 inches in diameter. The opening in a matching NOS 2343 truck bushing measured to be .311 inches, so the difference is about .0025 inches.
The drill bits I try to use to protect the holes are usually just a bit over the axle diameter, on the order of magnitude of a few thousands of an inch.
I have a nice set of drill bits in inch, number (1-60) and letter.
I am careful to clean the bits and put them away in their case after use. So I’ve had the same set for years. (I have broken some of the smaller ones, in the 55 to 60 range.)
On occasion I have also used the drills as a poor-man’s gauge to measure the diameter of holes.
The number set turned out to be a very good investment.
I don’t know whether I’ve ever used the letter drills.
Thanks for the help guys. I think I see the big picture here now. I am going out to get a caliper tool. May look into the reamers. Definitely need a full set of drill bits.
Roger
Roger,
A good tapered reamer used with a tap handle is an excellent investment for these types of jobs. They don’t need to be the hi-end expensive ones either, just remember to use a couple of drops of oil to help the reamer do it’s job.
I do not have any real expertise with reamers, and am looking to learn.
I understand that properly used, a flat reamer would give superior results to a drill bit.
I do not understand why a tapered reamer would be superior.
By the reamer’s very nature, wouldn’t the bearing surface be tapered, leaving only a tiny portion in contact with the rotating axle? Then in turn, wouldn’t that tiny portion wear quickly?
I have tapered reamers, I use them to enlarge holes in thin materials.
I have the same thoughts about a tapered reamer.
Roger
Sorry about the confusion. It is actually a “hand reamer”, the confusiom came from the fact that a short portion of the lower part of the reamer is slightly tapered under the finish size so it will start and act kinda like a centering guide for the final cut. [B)]
Gotcha!
I looked on the Harbor Freight site. I certainly could have missed them, but I did not see reamers in the size range that we would probably need for Lionel trains.
Most of the reamers I see on the Micro Mark site are tapered for hole enlargement.
I did see a set of six for $33.50, a set of seven for $54.50 and a set of fourteen for $97.95.
It’s not clear to me how many pieces in each set would be useful for trains.
So where would one buy them?
I am also curious about how one would use the reamers. It doesn’t seem that high precision work would be that well done by hand. The Micro Mark seven piece set indicates they are to be used in a milling machine, lathe, or drill press. I have a drill press, but I do not think it has the precision of a lathe or milling machine.
I can only recall one reference made by Lionel to reaming bearings. According to the Lionel Service Station manual, whistle motor armature bearing are line-reamed due to the high RPM of the whistle motor.
Thoughts?
This (untried) process might work: Subtract the the inside diameter of the bearing when pressed into the chassis from the inside diameter of the bearing when loose. Add this amount to the inside diameter of the bearing when loose and drill the loose bearing out to that diameter. Then press the bearing back into the chassis.
The result of that process would still be an out-of-round bearing caused by the bearing deforming as it is pressed in. The bearing O.D. should be machined, sanded, or filed to be a light press fit, and then it will not deform when pressed in. Barring this, the bearings can be either carefully hand reamed, or if a drill press and decent vise is available, the truck and bearing squared up in the vise and 2 bearings reamed at once, in line.
Single reamers (as well as most any other machine tool) can be had from MSC Industial. These are 3/16" reamers that would probably be the correct size for the job.
Larry
I got a caliper tool and measured the axles. The axle is 187.5. The best I can see on an original factory installed bearing still in a truck that had never seen the track is 188.5. So it needs to be a bit bigger. Thanks for the web site I will see if there is a reamer that size. Keep this in mind for any future 671/681 engines because it is the same axle used.
So how is the reamer used? You don’t punch out a bigger bore with it do you?
Roger
A reamer is used just like a drill. Drills, because of how they are made, do not drill truly round holes, but rather a 3 lobed hole. A reamer is used to open up a slightly undersize hole, and to make the hole round.
Here is a .1885 reamer that should do the job for you.
Larry
Larry, I can see that the inside hole through the bearing would be non-circular if pressed into a hole in the casting that is not circular, or if the outer shape of the bearing itself were not circular. But, if they are both circular, I expect the center hole simply to be slightly smaller and not particularly distorted.
